palm or palmetto
Turning Palm or Palmetto
A lot depends on what you want to turn. Finials, bottlestoppers and other small items aren't very difficult if you're able to use the outer section of the trunk. The outer section of the trunk of most palms is the hardest and easiest to turn. The inner sections can get very soft and punky but it depends on the species of palm. If you want to turn a bowl or platter and you have a very soft section of the inner part of the palm, I have used several coats of Minwax Wood hardener to toughen up the tenon to grab in a chuck. I also have used CA glue on the tenon. You may also want to coat the inside of the bowl with wood hardener when you get to about 3/4" thickness. Sharp tools and light cuts are critical. Palm tends to be very abrasive and dulls tools quickly. The results can be spectacular!
Tim Carter
