Get a vicmarc outboard tool rest
I have a Jet 1642 also. I mounted a Vicmarc outboard turning rig to it with minimal fuss (there's a post on this forum from me with instructions and a picture if you search for it). I ordered the Vicmarc rig from Craft Supplies (who I also sent the plans to). Since the Vicmarc rig bolts to the lathe (you have to drill and tap four holes) but only has a single post going to the floor, the stability is tremendous and the articulating arm positions the toolrest most anywhere you want it. Floor stands are too cumbersome, hard to level and the legs always seem to get in the way. I love my set up and gained 10" of swing!
Here's instructions:
Jet 1642 w/Vicmarc Outboard attachment – Setup
Specs.
Top bracket measures 7 ½ in. from top of lathe bed
Lower bracket mounted 6 ¾ in. from top bracket (measuring top-to-top) – this could be mounted as much as ¼ in. or ½ in. lower – 7 in. or 7 ¼ in.
Top right corner of top bracket is set 1/8 in.out from leg (protrudes this much) – caution – don’t fudge this to the left any or when you drill bolt hole into leg, you’ll be drilling into the corner of the left hand leg.
This setup will yield the following:
Spindle center should be 16.5 in. from right edge of top bracket, measuring to that part of the bracket that sticks out to hold the large pin that the first arm mounts on.
Spindle center measures 18 ½ in. to the first arm when it’s locked in at 90 degrees from lathe legs. – if lower bracket is mounted lower than specified, this measurement will increase accordingly.
Installation notes:
Lathe tech at Craft Supplies recommended drilling and tapping holes to mount brackets as opposed to using through bolts, although that’s what Vicmarc supplies. I used 3/8 in. x 16 t.p.i. standard tap and a ¼ in. drill bit which yields a 1/16 in thread to accommodate 3/8 in. x 1 ¼ in. bolts I used to mount the brackets.
Supplied mounting bolts are metric – ditto holes in bracket to match. If you use 3/8 in. bolts, you have to drill out the holes in the brackets to match (the metric size is just slightly smaller) – you could use supplied bolts if you have a tap and drill bit to match but I didn’t.
I used C-clamps to hold the top bracket in position and a centering drill bit to mark the EXACT center of holes on vicmarc bracket. Then I took the bracket off and used a 1/16 in. bit and drilled a pilot hole then I drilled the ¼ in hole and tapped it. Make sure to drill holes straight. The cast iron legs drill and tap very easily. A drop of thin oil is a good idea when tapping the holes. You may want to drill one hole, tap it, remount the bracket with a bolt, make sure it’s in correct position, clamp the other side and mark that center, remove the bracket and then drill and tap the hole for accuracy.
Once holes for one bracket are tapped, mount it with the bolts tightened down, put the big pin in and tighten set screw then feed the other bracket onto the pin, lock it in position and mark those holes as above, remove the second bracket, drill and tap one hole, set bracket back in position, bolt it down, mark second hole, take bracket off, drill and tap that hole.
Bolt everything up – note – you may have to loosen bolts a bit to get big pin through one bracket, through the first arm and then through the second bracket. Once that’s done, then tighten everthing up and mount the short arm to the first arm.
YOU HAVE TO SHORTEN THE TOOL POST BY CUTTING OFF THE BOTTOM if you mount this to a 16 in. lathe (the Vicmarc has a 20 in. swing). For the Jet, I cut off 2 in. but in one case, on a platter, using a scraper, I found out this was a bit too much (because of the short length of the 12 in. tool post supplied with the Jet) and had to jack up the post with a piece of steel). Cutting off 1 ½ in should be okay. I did the cut off on an old chop saw with a metal cutting blade in it – worked great. Watch the sparks, though and don’t set anything on fire! Remember that the amount cut off depends on whether or not you use the adjustable legs and how far they are extended. If your lathe is bolted to floor, better judge for yourself.
Once mounted, the outboard rig essentially becomes part of the lathe and is rock solid when tightened down and offers a much better solution than a floor stand. I haven’t found any twisting or teeter-tottering of this setup. You may want some additional ballast on the tailstock end – I put two 50 lb. sandbags on top of the ballast box I built from the Woodcentral design.
That’s it – have fun!
--- Denny
PS - I'll email you the picture.
