  • Congratulations to Dave Roberts for "Low Rider" being selected as Turning of the Week for December 1, 2025 (click here for details)
Original Powermatic 3520
Mount Juliet, TN
First post! I've been turning for about 3 years. Started on a Delta midi then moved up to a Grizzly G0838 (that I'll be keeping). Recently we ran across a great deal on an original powermatic 3520 and even tho I didn't actually need it my husband and I decided to get it. It needs a new VFD and my husband is a programmer and very handy so that will be here tomorrow and I expect to be up and running this weekend. He's already upgraded a Nova to variable for my nephew. The PM came with no documents so I'm looking for a manual but all I can find is the 3520A manual. I also think the banjo has been changed out because I read the 3520 had a 1 1/8 post size and this one uses my 1 inch tool rests perfectly. It came with a bed extension which I'm happy about since I can slide the tailstock out of my way when not needed. Honestly just looking for some insight on the machine. Pros and cons, info about adding a tachometer, maybe other things I haven't thought about. Thanks in advance.
editing to add - total for the machine, the new wiring in the shop and the VFD came to $1175. That's a deal for such a great machine. I'm really excited.
Nice get - especially with the extension. Looking at it, there don't seem like any major differences between yours and the 3520A I have. Great machines - mine lacks the tach too, and I don't feel the need to add one. Make some shavings!!! Not much in terms of cons with that machine, once you get the VFD sorted out.
I guess I'm just used to the tach so I was considering trying to add one. Can't wait to use it. My Grizzly has been great but I think the Powermatic is an upgrade even tho it's older. When this started I never thought I would end up as addicted as I am. I was gonna make candlesticks, maybe a rolling pin or two. 😂🤣
Can't wait to see what you turn on your new beast. I think you should do what makes you happy about turning. If you feel more confidante and comfortable if you have a tach then by all means add one. You can make one really big candle stick on that machine.
Gregory
On my machine with no tach you can just use the position of the speed controller knob as a speed reference. For my 3520b it is a linear knob so turned all the way is 1200rpm then tuned halfway is 600 rpm…
I had a very early version of the 3520A. Mine actually had a small fan under the baffles on the phase converter to keep it cool. I had to put some fine mesh screen over the top to keep chips out. Speed ranges were 0 (actually about 10 or so rpm before it turned off) to 1500 on low speed range which you need for coring. High speed range was 1500 to 3000. On the B model they changed that to 50 to 1200 on low range and up to 3000. The original pressure plate on the bottom of the headstock was cast iron which snapped when I was coring some black locust. That was replaced with a steel plate. Do check that out. The original post was 1 inch. I stripped a couple of the handles on the set screw for the banjo and had a friend make me a sliding T post for the set screw like is common on bench vices. Much better. My set screw did have a brass insert in the end to keep from marring the tool rest post. Can't remember exactly, but the original tool rest was at least 12 inch, maybe 14. It cracked at the top of the post. The whole thing was cast iron. They changed that too. A very good lathe, you will get lots of miles out of it.
Thanks for the reply and the info. I don't have a coring rig (yet) but I'll check to see if it has the original plate. The guy I bought it from wasn't the original owner and he didn't have a lot of info. I have a set of robust tool rests that fit just fine. It didn't come with any. Now if I only had a robo hippy rest I would be happy (just kidding). We plan to put a shield on the fan. I saw your comment on that in an old post.
Guy here in S Cal w/a machine shop added a tach for me, new detachable VFD, new belt and bearings, all on my 3520a. He also replaced the spindle lock with a steel one—the cast iron original cracked and broke. My lathe is outside so bringing the VFD inside is to protect it. See my picture in upper left corner—that’s the lathe. Enjoy!
I have the 3520b and two friends have 3520a lathes: no practical difference between the two models except for the speed control. But guess what, none of the better turners I know pay any attention to the speed numbers, they turn to some speed that works for them.
A common question in demos, mostly from beginners, is "What speed are you using?". The answer is usually "Have no idea, let me look". I personally turn most spindles, especially small and thin, at this speed: Fast. And platters and bowls at "Slower". Sanding is "Slow".
If the speed display on my 3520b quit working I'd probably not bother fixing it unless I planned to sell it.
My mill and metal lathe both have speed readouts and sometimes that can important, as is when drilling certain materials. My drill presses don't have a readout but I bought a cheap optical tachometer from amazon and can check if needed.''
The banjos of the full sized lathes I have and all I have used accept a 1" tool post. I understand some Oneway lathes are different. The 1.125 post size is new info for me. You can contact Robust (who arguably make the best tool rests available) and ask - they know everything about current and probably about past lathes.
If I left my lathe outside here in Middle TN it would be a mess of rust in no time! That's crazy that you store it outside.
The new VFD delivered this afternoon and my husband installed it. We also had to run a 220 plug for it so I can have it and my Grizzly available. Finally got it running about 10pm and I put a piece of walnut on it and gave it a whirl. It feels super stable and I love the tailstock (the Grizzly tailstock is pretty bad). I'm not all that worried about the tachometer, it would just be nice till I get a feel for the machine. Now for the accessories! All my other machines have been 1x8tpi so I don't have any faceplates or chucks for it yet. Not a big deal. I can use an adapter temporarily even tho I know it's not ideal.
I
Think it's funny you say temporary. While you'll more than likely will primarily use the accessories you procure for this machine, since you have an adapter you'll grab that old chuck from your other machine when you do not want to take a piece out. Congratulations on turning on your new lathe, enjoy it.
Gregory
The adapters are not a big deal. More precisely it's barely off of ideal. I slowly migrated my stock of 1x8 chucks to other turners and have 1 left for my mini lathe the kids use. I wouldn't sweat the adapter or purge the 1x8 supply of chucks and faceplates any faster than you want.
As others have indicated, you can get a super cheap laser tach and measure the speeds and belt positions and mark the dial if you really need to know.
The only time I worry is cole jaws which seem to fan at higher RPM and even then I just turn it down
I'm not a fan of cole jaws period. I never got comfortable with them. I have a vacuum chuck I use to take my tenons off and I love it. Unfortunately it won't fit the Powermatic with an adapter since it goes thru the headstock. As long as it's 16 inches and under I'll still do that on the Grizzly.
That’s funny. I have a vacuum chuck that I used to use all the time, but also have Cole jaws that I find myself using more regularly. Recently bought the extensions for them to increase the capacity up to almost 14” I think. My daughter 3D printed some buttons (is that what you call them?) for me that work in expansion or contraction mode. IMG_6999.jpeg
I guess it's what you find comfortable. It does take a few minutes to get set up. I usually wait till I have more than one to do and then have a bottom cleaning session.
My shop for years was on a front porch of a small house - I had a radial arm saw and some hand tools and made many things, some we still use today! Sometimes I worked sitting on the sidewalk. I covered the saw with a tarp and cleaned off rust when needed. Worked that way until I cleared a spot behind the little house and built a 20x20 building and ran underground power to it. What an amazing improvement!
I have a very heavy custom cover over my PM3520.
Brent over at Robust does make my bowl rests now. I quit my business because it was taking up all of my play time... The Robust tool rests are great. I think Brent was the first to use hardened drill rod for the top surface of the tool rests. Far better than cast iron.
I didn't know that. Thank you. I follow Lisa Ramlow on youtube and she uses one of yours (with the sticker still proudly attached) and has talked about it.
Ozarktoolmanuals.com sells scans of the manual for the 3520. (They sell them a little cheaper through Amazon, but you might want to spend a few extra dollars to support a small business by buying it direct.)
I bought a couple of the Robust bowl rests some years ago. Should be useful for some things but I've not used them once. For me, the standard straight rests do everything I need. I think I have 9 or 10 straight Robust rests plus a couple of the curved ones - different sizes and different post heights (the PM3520 needs a different post height than the Jet 1642). If you call and order, be sure of the specifics of the lathe they are for. He carries or will make rests to fit anything.
When I'm doing demos, I always take the robust rests when I don't know for sure what the club will have. I've gotten where I hate to turn with any other tool rest.
That’s funny. I have a vacuum chuck that I used to use all the time, but also have Cole jaws that I find myself using more regularly. Recently bought the extensions for them to increase the capacity up to almost 14” I think. My daughter 3D printed some buttons (is that what you call them?) for me that work in expansion or contraction mode. View attachment 70888
Also recordpower makes the rubbery version of those. I stumbled upon them in the back of a turning supply store
One thing that might be useful at times: A friend, learning to turn bowls, wanted to use my Cole jaws to hold his but regardless of the threaded holes we used the stock rubber "buttons" would not fit his bowl. We ended up taking off the buttons and replacing them with short pieces of clear plastic tubing from the hardware store. Worked well.
BTW, I once went to the hardware store and bought 3' of every size of clear plastic flexible tubing they carried. I can't tell you how many times pieces of that have come in handy (or saved the day).
The differences between the original 3520 and the A and B are not very dramatic. You definitely shouldn't worry about missing anything. I've never had a tach and can't imagine how I would use one now.
Your banjo appears to be fresher than the rest of the lathe, but looks like the standard model for an A, so maybe it's original.
You don't have the little bracket around your spindle lock that can be loosened and rotated to hold the lock in the engaged position. It's widely considered an annoying aspect of Powermatics, and there are various solutions, but all I'm aware of require the bracket. You might see if the former Mustard Monster user web site materials are still available, as there might be a fix posted on there. Maybe it was @Rich Colvin who collected that site's content and was going to make it available.
It's hard to see from your picture, but your leg levelers aren't visible, so you might not have them. Unless you posted up playing college basketball, you will probably be fine without them. Since the Powermatic centerline height is pretty high (44" IIRC), if you are a petite or even average height woman, it might even benefit you to have a platform on which to stand when you turn.
The tool holder that attaches to the headstock end uses threaded screw holes which you probably don't have. If you really want one, holes can be drilled and tapped in the iron legs. The screw holes in the tailstock end are unthreaded on the 3520, and threaded on later models. You've got a bed extension bolted on, proving the unthreaded holes still work.
Enjoy!
Thank you for all the info! It had three leg levelers on it. My husband installed new ones and I can't decide if it's too high or not. I'm fairly tall (5'9) but we'll see.
I don't have holes for anything but the VFD on the headstock. I'd like to have a tool holder but it's not a deal breaker.
I would like to drill and tap some lower holes to drop the bed extension down for extended turning. I have that feature on my Griz and I like it. If not I guess I'll figure out a floor stand toolrest when it comes down to it.
The tool holder is a simple piece of sheet steel with a 90-deg bend on one edge with holes for screws. It fastens to the lathe leg, not the headstock. It has a number of rectangular and round holes in it - I use mine for things like drawbars, knockout bars and such.
I think the holes are also additional mounting holes when mounting the bed extender in the lower position to hold the extended tool rest. I've never had a need for that, but love the bed extender for ... an extended bed ... and to hold sliding tool trays I make to fit between the ways of every lathe, like this one for the jet 1642.
There's one version that's a sorta U shaped piece (wood or etc) with a couple magnets to hold the spindle lock in.
Another uses a toggle clamp screwed in where the bracket would go.
I have mine in a bin somewhere. I did make a tool holder for my headstock that holds chuck keys, 4mm Allen, etc: https://dlwoodturning.com/headstock-tool-rack/
Adding a tach is pretty simple. I added one to my American Beauty with this kit form Amazon.
4 Digit LED Tach + Hall Sensor and Magnet
I used essentially the same kit put a tach on my metal lathe and it's simple and works great. To power it you can use any 5-12v wall wart power supply. The hardest part is figuring out where to mount the sensor and magnet. I'd be glad to help out remotely if you need it, and there are plenty of knowledgeable folks here who will gladly help.
If someone doesn't need a continuous digital tachometer readout, but perhaps just wants to check the speed or calibrate a speed knob, there's a simple option that works very well. I keep this optical tachometer in my case of instruments (along with thermocouples, wind speed, light and sound meter, etc.)
All that may be needed is stick a small piece of reflective tape on the shaft, turn on the machine, aim the hand-held tachometer at the rotating shaft, and push the button. The RPM will be displayed. This will work on anything and no magnet needs to be mounted, no need to supply power. It has a battery in the handheld reader - claims to read from 2.5RPM to 99999 RPM. (If anything is run up to 99999 rpm I'll be in the other room.)
I've used this to make some lines outside of a speed knob so I would know the approximate speed anywhere on the dial. For example, on one machine I drew a line at 500, 1000, 1500, etc. since I didn't need to know the exact speed. In fact, I find I seldom need to know the exact RPM of anything.
Just an idea.
Are the files for those Cole jaw buttons on line somewhere? I’d like to ask my son in law to make a set for me. I have been using rubber corks, but they are too soft
Mike, I should be able to dig it up. I got it a few years ago from a lovely turner in Denmark. I can’t remember how I learned of them. Maybe on this site? In any case, he gave me permission to share them with the caveat that he took no responsibility for any failure, injury, etc. I’ll make the same disclaimer/condition. Give me a bit of time to see if I can find the file.
