Opps
Larimore, ND
Don't do it! Don't set a small log on your band saw table, start to cut then realize you didn't turn on the dust collector. I pulled the log back, make sure it wasn't rolling forward, then leaned over to turn on the collector. In that very short couple of seconds, log rolled forward and BOOM, scared the poopers out of me. looked back up and saw log was gone, saw had locked up and blade with a new, fancy twist going. Besides the pride thing, I lost a fairly new 1" timberwolf blade..... so, just DON'T take your attention off what your cutting, not even for a second.
I usually use a cradle but was having a serious brain fart that day. I guess another thought, don't do it when tired!
Did it break, or just twist/kink the blade? I did the same thing once and was able to remove and straighten it out enough to use it. A bit more noisy, but a good reminder.
It just twisted and drove it into the throat plate. Messed up a few teeth. I just remove/tossed it and chalked it up to lesson learned... could have been alot worse.
Who says you can't teach an old dog new tricks? LOL, it's one I won't soon forget.
