• We just finished a fairly major forum upgrade. If you are having problems using the forums, please clear your browser cache and that should clear up any issues. Otherwise post in the Help Thread or email us at forum_moderator@aawforum.org. Happy Holidays!
  • It's time to cast your vote in the December 2024 Turning Challenge. (click here for details)
  • Congratulations to Vincent Luciani for "Flower Pot" being selected as Turning of the Week for December 23, 2024 (click here for details)
Open segment candle holder
Toronto, Ontario Canada
www.phoenixwood.ca
Started candle holder on the 23rd and finished it today - Bloodwood base and top with mahogany & walnut accents between birch. Wall thickness is about 1/8". A tea-lite candle fits in a 1 1/2" drilled insert in the base and gives off a pleasant light in the dark. A great way to use some left over bits of wood. Finished with WB lacquer and buffed. Bottom is flocked brown.
Ray;
That is a very impressive piece. What are the dimensions of it ? You said a tea light fits in a drilled insert in the base. Does that mean the top opening is big enough for it to be put in from the top or does the base have a hole in it that sits over the tea light.
Another novel idea may be to install a mini base light kit that uses a 7 watt light bulb like a night light.
W.Y.
