I have a stronghold, and #2 and #5 AL profile jaws, #2 serrated tower and #3 profiled tower.
The tower jaws, both serrated and profiled, have a smooth 1/4” deep dovetail at the top and then serrations on down. Got the tower jaws for long tenons for deep hollow forms, but they also work great for bowls and platters. An often mentioned criticism of taller jaws is vibration - I've compared the #2 std and tower jaws turning similar size bowls from the same piece of log, and the criticism is unfounded in my experience. So many variables play into resonance at the cutting edge that I can't tell a difference. I understand the theory behind it. One thing 40 years of engineering showed me - theory is no substitute for tested practical application.
Having used all the types, I don't really have a favorite. They all work well. When I have had a piece come out of the jaws, it's been poor tenon work - no contact at the outside of the jaws, tenon too short, bad spot in the wood, etc. My least favorite is the #2 tower jaws with a circle DT at the top - I often wish I had the profile version. The versatility of the Oneway profile does win over a typical round serrated or dovetail. The profile shape gives a better grip everywhere but the perfect circle dia, and I am rarely at the perfect circle dia. The profile allows use of the full grip range of the jaws/chuck with more confidence vs typical round jaws. They are also superior with square work.
One place dovetail jaws have an advantage is with short tenons. With a dovetail, you can get away with ~3/32, maybe less depending on how much load will be generated. The profile jaws really need a minimum of ~3/16". For smaller more delicate work the DT jaws are probably better, since that's generally when you run into short grip surfaces.
