I am considering a Oneway easy Core for my Craftsman 15 x 18" lathe. The one I am considering is the 16" base unit. My question is if the stands are short enough to allow my 15" lathe (7.5" from center of drive to bed) to properly align the cutting head. I see an adjustment screw in the bottom of the rest. I assume it is extended to align the cutting head with the center of the blank, so I wonder if drilling the hole deeper in the rest stand will be necessary?
If not, can I cut it off a half inch to make it work.
I know I should have a bigger lathe, but I am hoping with careful feed rate and sharp blades, it will work. I have the older craftsman "Professional" model with the infamous toothed belt reduction gear. I know that could be a problem.
