• It's time to cast your vote in the March 2025 Turning Challenge. (click here for details)
  • Congratulations to Tom Kamila for "Black Ice" being selected as Turning of the Week for March 24, 2025 (click here for details)
Oneway 2436 wont start
If you open the switch box that has the buttons in it, there's a switch behind the big red button. Sometimes the little switches come loose and simply need put back into place. Also if it gets moved or bumped regularly, the little wires onside can become disconnected. I would open it up and look for anything obvious.
Do as Wyatt suggests, check for loose wires and hit the switches with compressed air to dislodge any possible dust on the contacts. If that fails call Oneway and ask to speak to Shane. I went through this last week and spent 1/2 hour on the phone troubleshooting with him. Wound up ordering all four switches on a well-used 25 y/o lathe (on, off, forward/reverse and E-stop) as we couldn't isolate the problem. You will want to open up the inverter box to read any error codes as you walk through the process.
