• We just finished a fairly major forum upgrade. If you are having problems using the forums, please clear your browser cache and that should clear up any issues. Otherwise post in the Help Thread or email us at forum_moderator@aawforum.org. Happy Holidays!
  • It's time to cast your vote in the December 2024 Turning Challenge. (click here for details)
  • Congratulations to Vincent Luciani for "Flower Pot" being selected as Turning of the Week for December 23, 2024 (click here for details)
OneWay 2436 Spindle Height
Canton, Connecticut
I'm looking at a used 2436 but the spindle height is about 2" lower than the lathe I'm currently turning on. Is there a way to raise the height without compromising the stability? Thanks.
Depends on how old it is.
I The newer ones have adjustable legs. Requires jacking up the lathe easy with a hydraulic table and reposition the bolts holding the legs in place.
The older ones had leg sets available in various heights.
I suspect the one you’re looking at is the older
The lathe levels with bolt on each leg turned into a piece of steel with a depression for the bolt.
It sits on 4 steel rectangles. I think you’d be fine with 2 2x4 with a square of plywood under each end to give you the 2”.
Glue the steel rectangles on top of the 2x4s hold them in place with screws set around them.
The plywood squares make the 2x4 sit solid plus makes the 2 in 2x4 a real 2”
I boosted the height of my Problematic in a similar way to Hockenbery's suggestion. It had adjustable feet, but because I wanted it taller, the bolts were extended further than they could tolerate. I used stronger bolts and had a wood foot under each of them.
A hydraulic jack makes it quick and easy, but a guy could use just a lever of some kind (lumber or steel) to lift each end; just have to block it up solidly to safely work under.
Just about everything in my shop is jacked up as hockenbery suggests.
