I'd like to get opinions on whether it would be worth it for me to upgrade the PM 3520c that I've had since Dec 22 to a Oneway 24/36 3hp.
Overall the powermatic has been good but I find myself pushing it's limits fairly regularly. I had the great fortune of becoming a regular at a big farmers market this season but have struggled to keep up with production demands. I was not prepared for the success and did not have enough bowls rough turned. (I do also make other products, but bowls are the staple) This summer I am looking to prepare fully and plan to rough turn 1-2000 bowls. With the PM I start with max 18in diameter billets I've taken to a hexagon with the chainsaw then I usually get one or two cores out it. I'm frequently having to start slow due to imbalance and stalling when trying to take a bigger cut. I also have to swap the coring set up on and off between each piece. That's not too bad but it does slow down the production.
My plan is to get the 24/36 with the outboard extension. This would let me keep the coring rig set up and allow me to use the tailstock side for initial roughing. Additionally I'd plan to use the shortbed side for finish bowl turning. I don't like having to get everything super clean before sliding the headstock on the PM so I almost never use it in the short bed position. Additionally I'd plan to bolt the OW to the concrete slab to allow me to get larger unbalanced blanks moving faster. The whole point of the upgrade would be to better handle production turning this summer.
The ability to have the advantages of a 3hp fixed headstock lathe while also having the shortbed set up is what makes me lean toward the Oneway over a Vicmarc or Robust. Of course, in theory I could keep the 3520 but I don't have a ton of space and it feels like getting the money out of it would also help with the cost of the potential upgrade.
I would appreciate any thoughts from people who have used both or if there are better options I have not considered. Thanks.
