  • Congratulations to John Lucas for "Lost and Found" being selected as Turning of the Week for January 13, 2025 (click here for details)
Oliver 2018 lathe
If I'm not mistaken, it sort of looks like a Reeves mechanical variable speed drive on that lathe.....although, it does appear to have two speed ranges. I had a Northwood lathe with a single range Reeves variable drive. (Northwood was a machinery importer that came and went in the 1980's.) If I could go back to that method of variable speed, I would not. It is slow to change speeds, and wears out belts quickly.
MM is right.......It appears to be capitalizing on a once trusted name in lathes......but, is nothing more than a knock-off cheaper version.
