- Joined
- Jan 27, 2005
- Messages
- 13,020
- Likes
- 5,425
- Location
- Dalworthington Gardens, TX
- Website
- pbase.com
The turning challenge for October 2022 is different in that it is only for new woodturners. So, if you have been turning for less than two years [EDIT: Click here for the updated definition, this challenge is for you. The challenge is to turn a bowl, but not just any old bowl. Nearly every one of us initially made bowls that look something like what is affectionately known as a Fido bowl ... a bowl that has a more-or-less flat bottom and somewhat vertical sides, I think that our subconscious mind tells us that we should aim for the biggest possible bowl from the piece of wood mounted on the lathe.
Instead of the biggest possible bowl, this challenge is about expanding the envelope and aiming for other forms that you can get out of that chunk of wood on the lathe. So here are the details of your challenge:
And finally, the fine print from the official AAW Forum legal consultants -- Dewey, Cheatum, and Howe:
- The challenge is about form and not beautiful wood so scrap lumber or plain vanilla wood would be a great choice for this challenge. You can even paint it if you wish.
- The diameter shall be between 5 and 9 inches.
- The maximum height of your bowl shall be no greater than 2½ inches.
- No vertical sides and no flat bottoms are allowed.
- Embellishments are not allowed.
- Your choice of finish (lacquer, shellac, varnish, oil, wax, leftover rattle-can, or latex house paint ...)
- Your goal is to turn a shallow bowl that has a smooth continuous curve without any humps, bumps, dips (AKA, dig-ins or catches), corners, or straight sections.
- Aim for an even wall thickness (we will take your word that the wall thickness is sort of constant).
- This is not a thin-turning contest so thicker walls are preferred.
- The elliptical shape shown below is just one example of a smooth continuous curve, but there are other acceptable shapes such as hemisphere, parabolic, and catenary. There are many other advanced shapes such as ogee and calabash, but this challenge is to make a bowl with just a simple continuous curve.
- When photographing your bowl aim for a shot that reveals both inside and outside shape as in the example in the foreground below:
- Only one entry per person and only one photo of your bowl.
- Entries must be posted in this thread.
- The deadline for posting entries is midnight Coordinated Universal Time (UTC) on October 25, 2022.
- As always, this is a turning contest, not a "moldy oldie" photo contest, so in fairness to everybody, make sure your work is something you have made after October 1, 2022.
- You may not post any photos of your entry in this month’s challenge in any other thread or in the gallery until the voting has ended and a winner has been declared.
- Voting will take place from October 26, 2022, through midnight UTC on October 31, 2022.
- Solicitation of votes will result in disqualification.
- The winner might have to pass a lie detector test before collecting the prizes. Good luck, have fun, make shavings, and let the chips fall where they may!!
