Nova Chuck problem
Staunton, VA
So, I bought a used supernova chuck off Ebay and have a problem; the new insert I got doesn't fit the chuck. It appears to be a slightly older chuck; its the same roughly 4" diameter body, but the thread pitch on the insert that was in the chuck--1x8tpi and the new insert, 1.25x8tpi are slightly different. The woodcraft site says the inserts match and are interchangeable with different Nova chucks, but it doesn't fit.......
The chuck body just says "Nova chuck", but it was listed as a SuperNova, not a supernova 2. The teknatool and woodcraft site seems to say that the chuck inserts and jaws should be the same for both models, but I'm stumped. I don't really need the chuck, I have 2 stronghold chucks with #2 and #3 jaws on them--I don't like changing jaws. I wanted this one so that I could have a chuck with non-marring jaws for box making.
Has anyone had similar problems with older supernova chucks not matching new chuck thread pitches?
Nate,
Did you buy the true Teknatool brand of insert from Woodcraft or their Woodcraft brand. Some of the Woodcraft brand units have not been seating right and in fact Teknatool has a warning on their web page about using "off brand" inserts. If it is a Woodcraft take it back and swap it for a Teknatool unit - will cost more. If it is a Teknatool unit I would contact Tim Geist the USA rep for Teknatool and get his help. They have switched all production to China and I keep hearing about slight problems from the production change but Tim will get it straightened out.
Wilford
