New Mini Hollowing Tool!
Ormond Beach FL
turnedbygeorge.com
My friend Steve Sherman is developing this hollowing setup for close work for small pieces. He's calling it "The Nano Revolution," and I've got to say, the tools match the name. I'm the "turning thug," I usually stress tools to the max. This evaluation is no exception. I haven't spoken to Steve yet, and there is a good chance that you are reading this before him.
The cocobolo piece I just finished is probably as big as one could safely turn., maybe a little taller and narrower, but that will be pushing it.
My initial observation was that for my big fat hands, the knob on the end of the handle/grip was a little awkward, so he turned off the knob... Better for me.
The only other "negative" for me is that I keep running the offset hollower too hot which causes the super glued tip to come out. Here again, I'm AGGRESSIVE. I'm imagining that I would have the same kind of issues using the Elsworth tools with the glued in tips... This might be resolved (for me) with a little set screw to hold the tip in place.
Now, the GOOD stuff:
The tool steel stays sharp for a long time and the adjustable handles makes it pretty easy to have enough handle behind the tool rest to give excellent tool control.
So far, I have a straight and offset (Elsworth type) cutter/hollower set, a double ended Bedan/beading tool that works well. I like the beading end, I used it to form the bottom of this piece.
AND (I have to say) my favorite a round cutter/scraper that could smooth just about anything.
These are not all of the available tools, just the ones that I was given to test so far. As more roll out, I'm sure I'll get a chance to test them.
For small stuff, boxes, ornaments, small hollow forms and the like, these are easy to handle and work VERY well at the jobs they were designed for.
For me, there was practically no learning curve, the only "problem" that I had was making the bottom a bit too thin.
You will notice that the rim tapers in a bit, that gave me just a little more clearance so that I could hollow out further. I welcome questions as this is the first tool that anyone has given me to evaluate, and I'm sure that I am leaving out pertinent information.
Update:
Spent most of the day with Steve and 20+ other guys from our area, doing the "Hollowing on the Hoosic" get together. I had a chance to ask a few questions and get some updates.
It turns out, that I got the very earliest version of the tool.
The glue for the cutter bits has been replaced - I got a newer replacement, I'll let you know what my findings are.
We spent the day turning, and Steve and I got the chance to work the tools and show off a bit. We were part of a challenge, and as many know, I don't normally turn much tiny stuff (what this tool was really designed for), so Ken Evans selected a couple of TWIGS for Steve and I to turn as a team... Of course, we sued the Nano... And so did a number of other people, meeting with surprised success.
Keep in mind, Steve is still developing the tools so I'm sure that there will continue to be changes, but not much in the way of significant improvements. The Nano Revolution is at the point where there will be a larger variety of tested and approved tools/cutters, the handles and overall function is VERY solid.
If you're interested, Steve told me that Warren Cutlery in Rhinebeck, NY will be involved in the manufacture and distribution (845) 876-3444
These are the two pieces I did at the day long, fast and dirty and I tried to go THIN too fast (still not REALLY used to the tool) we were on the clock, and I wanted to get them done - one GOOD one would have been better, in retrospect.
I have no financial interest in this tool or affiliate individuals or companies, I am merely reporting on the tool because I was asked to take the tool out for a spin. Fortunately for them I really like it.
