I have no clue as to where the idea came from that low rpm will burn up your motor. With my 3520A, my American Beauty, and now my Vicmark 240, they have had no problem. With the A, I sanded thousands of bowls with no heat problems. When I had my AB adjusted, with Brent's help, I kept putting my hand on the motor to check the temperature, and it ran cooler when sanding than it did when turning. I need those slow speeds for sanding my warped bowls. I called PM when the B model came out and the tech told me the reason for having the minimum speed being 50 rpm, up from the old about 10 to 15 rpm was "you motor will over heat and you will fry your electronics!" I told them that I had sanded thousands of bowls at speeds far less than 50 rpm and the tech told me, "We have done tests in our labs and your motor will over heat and you will fry your electronics." My guess is that the braking, which is essentially what the lathe does when sanding uses no power, or almost none. TEFC motors, totally enclosed fan cooled, need the fan if it is being worked, not if it is in idle speed. Some use it for sanding, others for finishing. When I am turning bowls, my lathe works up a sweat!
