New Generation Nova Chuck?
Rockingham, Virginia
I read somewhere tha Nova has developed a new genaeration of chucks that are righty-tighty, lefty loosey for tightening. I was wondering if anyone has first hand knowledge, or read detailed info, and if previous jaw sets fit, as well as any additional features that might have been added, and quality of the build? I’m toying with getting a new chuck or two, and I have 4 SuperNova 2’s, and one original SuperNova, and numerous jaw sets.
I also have 4 Hurricane chucks which I like, but thought if there are new, more advanced features with the new gen Nova’s, that might be the way to go if compatible with my jaw sets.
Nova started selling their Pro-Tec G3 & SN2 chucks about a year ago. With these a clockwise rotation of the key contracts the jaws, similar to the Record Power, but otherwise the Pro-Tec's are the same chucks as the older models.
When I heard they were doing this I ran out and bought a third old style SN2, so all my chucks would contract & expand the same way.
The older version did not have the same plating; but it did use a hex key. I'm sure they are internally the same. I have two SN2 chucks, but sold my Titan chucks to go with Axminster.
The g3 still uses the T-handled wrench and not a hex key. I have both versions of the g3 and I think the biggest functional difference is the new 50 mm jaws. They now have serrations inside and seems like a slightly more angled dovetail at the top of the jaws. I don’t think it would be worth upgrading a body from the old style to the new one unless you need an additional chuck.
I bought a new one and the build quality is actually superior to the previous ones. I am not having any trouble with the change to righty tighty and the jaws are all interchangeable. The insert is a bit longer than previous, but has setscrews to secure to the chuck for reverse turning which my old one lacked. I was also able to acquire it from a Canadian company for around 150 or so including jaws and shipping.
I have two of the new SN2s. I thought that, compared to the G3s I had, the build quality of the new Pro Tec SN2s was a bit looser/sloppier. (Just one man's opinion)
I bought a couple Record Power SC4 chucks recently and I think the build quality of those is a bit better/tighter. I bought them because they were a tad less expensive and available as bare chucks without more unneeded sets of 50mm jaws and wrenches to sit in boxes.
All my jaws are Nova and they fit the new Novas and the Record Powers perfectly. Yes, the new 50mm Nova jaws have been redesigned. Do they hold better? Don't know.
Where did you find them in body only?
The body only Record Power SC4 came from Woodcraft. As a bonus, I got to use the holiday 20% off coupon.
I searched for a body only option for the new Pro Tec version of the Nova SN2 but, as far as I could find, they are not yet available, at least in the US.
The older version of the SN2 is available body only as noted above. I did not want to mix the lefty/righty/tighty thing, which as another reason I tried the RP SC4 as it works the same as the new Pro Tec Nova SN2.
Note that the Record Power SC4 requires an insert also. Note also that the insert itself is (or was when I bought them) about 1/3 less expensive than the Nova inserts. Another plus for RP.
Confusion sets in. What is the difference between the 23264 Supernova lite chuck and the 23262 Pro-Tek Supernova2? Can't tell from tools plus web page.
What was the name of the canadian company? I live in Canada!
Woodcraft have swapped out jaws for me when I bought a new chuck. At no cost. You don’t need to tak3 the jaws included.
Yup, I spent a fair amount of time going back and forth between sites to figure out the difference between all the different versions of sets and products.
As long as the seller shows the Nova/Teknatool item number, you should be able to go to the Teknatool site for complete details.
In general, the "Lite" sets have more basic packaging with fewer accessories.
If it doesn't specifically say "Pro-Tec" it is the old style Supernova chuck.
If it says Pro-Tec, the jaw tightening wrench turns the opposite direction, the jaw screws are Torx vs. allen or hex screws. The finish on the chuck is different, and the included jaws have been redesigned. I think there are a couple other design differences with the Pro-Tec but that's the important stuff.
Not sure what differences there may be between Supernova and Supernova2.
When I bought just a few weeks ago, the new Pro-Tec chucks were not yet available in a Lite version or as bare chucks.
If you don't mind the old version of Nova chucks, you can get them for significantly cheaper than the new Pro-Tec chucks.
When you ask about this stuff, check the info you get against the manufacturers' sites for details if you can. Resellers and their websites are often lacking detail. (Yes, check my answers, too!) After I had been shopping for a while, I stopped in and asked one of the woodturning specialists at Woodcraft about the Nova chucks they had on the shelf. He did not know what the Pro-Tec stuff, or really much about their chucks in general. If I had not double checked online on my phone, I probably would have bought the wrong stuff. He also didn't sell me the required spindle adapter insert, although I should have known to get that as well.
Don't get me wrong, I don't fault the guy at Woodcraft. They have a lot of products in the store and he can't be an expert on every product and line.
The first “ever” 4 jaw scroll chuck was made by Teknatool and called Nova chuck it was operated by Tommy bars very much like the Nova midi chuck. The Supernova chuck is a gear driven open back chuck similar to the G3 only heavier. It was replaced by the SN2 (Supernova2)
The problem most have with the original Supernova is the wrench that came with it. It has a wobbly head made out of some strange metal that broke easily. Finding a replacement wrench is nigh impossible. Timberly Woodturning in New Zealand has had some made up in the past that don't break and I found a woodturning place in England that had some but they were going out of business and would not ship to the USA. Thankfully I had a friend there who I sent it to after buying and he shipped it to me. Cost a lot more but now I have a backup for my 2 original Supernovas.
Incidentally, has anyone here dismantled a Nova chuck? One of mine has "stiffened" and I think the gearing needs a thorough cleaning.
I have dismantled a SN2 . The hard part is getting that ring off. I ordered a too but it would not work so made my own by grinding a profile on needle nose pliers. The mechanism is fairly simple and I think Nova has a video on this.
The jaws from Sorby and Record fit the SuperNova 2. However, as the Record is righty tighty and the others are lefty tighty, one must swap the #2 and #4 when fitting Record jaws to the SN2 and Sorby. This was covered in a review in the UK Woodturning magazine.
As far as I know all Nova jaws fit the Pro-Tech chucks. I just bought a Pro-Tek SuperNova2 and all the jaws I had for my G3 fit the new chuck. They also have begun to sell chucks that use quick change jaws. To make the old jaws fit these it takes adapters to use the quick change jaws.
The Nova Pro Tec SN2 and the Record Power SC4 are both righty tighty. I can't speak to Sorby. The RP and Nova chuck slides and jaws are numbered in the same direction/orientation. My understanding of the reason for jaw numbering is that the jaws are manufactured as one piece then cut into four jaws. They are numbered so that they are used in the same orientation as they were before they were cut apart. Righty or lefty tighty makes no logical difference unless one chuck brand numbers clockwise and one numbers counter clockwise.
Nova discontinued the quick change chuck, called Infinity, a couple years ago. They just couldn't sell enough to make it worth their while. It's a long story but I have three Infinity Chucks and aquired jaw sets 2-7 and love them. At one time they made a set of jaw slides (part #8100) to upgrade a SuperNova2 (part #8100) the Infinity chuck. They are long gone by now. I upgraded 2 SuperNova2's to get my 2nd and 3rd Infinity chuck. There is a nova part# 8200 that allows Supernova jaws to be adapted to an infinity chuck. I have upgraded several jaw sets to give me an extra set up #3 and #2 jaws which I use most often.
OK, thanks gentlemen....... :)
Looks like I need at least 5,000 lumens to match the fluorescent fixture I've been using. All the old fluorescent fixtures have their own power source, mostly through the existing incandescent ceiling lights.....so the linkable option is not necessary.
This is the information I needed.....thanks!
Nova still sells quick change chucks on their website with an indication they are in stock; at least some of the chucks/accessories.Interesting they are discontinued since I talked to them on the phone with questions about jaws and asked some about the quick change chucks and jaws. No indication was given that they were discontinued.
