This is my latest ornamental box from Purple Heart and spalted Boxwood. It is 40mm tall and 50mm in diameter. It is much smaller in height than I had intended a moments inattention whilst I was was cutting the basket pattern and I forgot to phase the rosette. As a result I had to reduce the height and make a new base from spalted boxwood.
The basket weave pattern was made with a cutter 2.6mm wide with a curved profile. I found that 2mm spacing between rows gave a more pleasing result rather than the conventional width of the cutter. The basket weave was cut using a 20 bump rosette.
The inside pattern was cut with a high amplitude 10 bump rosette and the pattern was then filled with embellishing wax prior to lacquering. The top was cut using an arch 7 rosette and the inside of the lid was cut using an unnumbered rosette. The top and inside the lid were enhanced with white CZ stones.
