- Joined
- Nov 1, 2013
- Messages
- 325
- Likes
- 737
- Location
- Gulfport, MS
- Website
- www.woodtreasuresbybreck.com
I have done some piercing and own a high speed micro motor tool that works very well on 1/8" or less thick stock.(some times even 3/16) what I am wondering is to those of you who own and use a pneumatic system say like the NKS 320,000 rpm system. I believe the bits are all 1/16" in diameter and your approach must be 90 degrees from what I have read. My question is once you have pierced a hole with a bit like this drilling it at a 90 degree angle can you then cut side ways to open up your piercing holes like can be done with the slower speed tools with bits or do you need to change bits before opening up the original hole?
I realize Bin Phoe uses his on 1/16" turned stock, to be honest I am not sure my turning skills are up to 1/16" thickness yet. can these tools pierce a little thicker stock? Any experience and advice would be appreciated. I am even looking at 45 degree angle lighted ceramic bearing dental drill on e-bay then putting a regulator and filter on my compressor.
