- Joined
- Jul 4, 2016
- Messages
- 3
- Likes
- 0
I'm looking for a high gloss finish that is good and safe for children's toys. Any suggestions?
Thanks for the feed back! I have many options now.John mentioned General Salad Bowl Finish and that was going to be my recommendation. It builds nicely and you can do three coats easily in a day, probably four on something like a toy. I generally do a minimum of three coats with. Is certified Food Safe for contact but probably not for chewing. As an aside, I have been storing the can upside down and it is keeping fantastically. No gelling what so ever after more than two years after opening.
Thanks for the feed back! I will try it.Any finish will be glossy if you fill all pores, level and sand the surface so it's smooth and then put on enough coats of finish to build to the point you can rub out the finish. I use oil penetrating finishes for childrens toys. They are going to chew on them so any high build finish like General salad bowl finish or polyeurethanes will wear off. It's just plastic so if ingested shouldn't do any harm but then why take the chance. If you sand to at least 600 grit and use a coat of finish such Mahoney's walnut oil and then buff it with the Beal you get a nice looking finish that's shiny but not necessarily glossy. Looks great to most people.
