  • Congratulations to Scott Gordon for "Orb Ligneus" being selected as Turning of the Week for January 20, 2025 (click here for details)
Natural Edge Bowl
Palm Springs Area
Just curious when doing a natural edge bowl. When you start out between centers what is the preferred way on the drive end. Remove the bark with a chisel, drill thru it with a Forstner bit, or pound the drive center into the bark.
Rich
Just curious when doing a natural edge bowl. When you start out between centers what is the preferred way on the drive end. Remove the bark with a chisel, drill thru it with a Forstner bit, or pound the drive center into the bark. Rich
The drive center must be in solid wood.
I select my center point and drill a 1/2 inch into the wood with a 1 1/4 Forstner.
Removing an area of bark with a chisel or a jointing pass with a chainsaw exposes solid wood the drive the spur into.
Never drive a spur into the bark. It will not hold reliably.
Richard,
IF you haven't connected yet, do find the inland woodturners. Riverside is just an inch away on the map.
They might even be meeting today.
http://www.inlandwoodturners.com
Wow that is a great find. Thanks for the tip. Yes Riverside is only about an hour and fifteen from here. I can't make it this month but I will plan on making it next month. They have a bunch of newsletters on line I will look thru before then.
Rich
