- Joined
- May 1, 2004
- Messages
- 43
- Likes
- 1
- Location
- Corpus Christi, Texas
- Website
- www.davidlauffenburger.com
I have a Bosch 12" Miter saw and when i make cuts with it the cut is uneven. When you look at the cut it looks like the blade flexes when it first starts to cut through the board and after about 1/4" it straightens out and then continues cutting. I have inspected the saw and everything is tight and i do not detect any motor bearing slop.
When i first got the saw it came with a blade and just assumed it was a cheap blade but i finally bought a Jesada Miter Blade so i shouldn't be having this problem.
I am trying to use it to cut segments but the cut is so poor that i can't glue the pieces together because of the gap on the top edge.
Any comments and suggestions would be appreciated.
Thank You,
Dave
Thank You,
Dave
