Congratulations to Gabriel Hoff for "Spalted Beech Round Bottom Box" being selected as Turning of the Week for January 6, 2024
(click here for details)
If you are able to get the inside diameter, outside diameter and the overall width of the bearing to be replaced most any bearing store can get you an excellent replacement. Hope this helps,
Other than ordering from the lathe manufacturer, if you are able to walk into a bearing dealer with the old bearings and the spindle, they can get about any size bearing you need (and better quality than OEM). Try these folks >> http://www.timken.com/industries/industrial/faq.asp
