Will microwaving a piece kill any boring insects without needing to reach 140 degrees (or whatever the number is)?
If that is true, then the wood industry would use that to sanitize the wood I would expect, however they are not as far as I know, the use other manners to do that, here's one that also refers to the other manners of heating the wood.A microwave does a good job of killing insects, the blood and liquids inside the insect will quickly heat up and expand and rupture cells and membranes in the organism and kill them.
I bet the wood cutting and treating industry would find out what is effective and government would allow just microwaving of the wood to sanitize it as is required everywhere to be used as crating and pallet construction material.
Would be like the Kilns they use, big enough for what it needs to be.I wonder if the industry knows about it, but can you imagine the size the microwave would have to be to use on large amounts of wood? It would have to be as big as a house as it would not be effective to do a couple small pieces at a time but yes, you do make a great point. Out of curiosity, when the ants come back out this spring, I might catch some on a piece of wood and throw it in the micro just to find out if it affects them.
Yes Reed, there was a write-up from Russ Fairfield on this, it was about these super fast drying with Dishwasher soap and DNA drying and Microwave, a bit like the bug killing we have going on, ETC.I know the lumber companies have tried the microwave idea for kiln drying wood, but discarded it. Not sure why though. Lots of lumber mills here. I do wonder what a vacuum kiln would do to the bugs. The wood that I have used that was dried that way cut like air dried wood
you got that right.... i learned from experience!And don't use the microwave in your kitchen. Especially if your married.
