McNaughton Micro Coring system
Central Michigan
I thought I should start a new post and sorry for hijacking the other one. :(
I just received the Micro McNaughton Coring System from the UPS guy last night. Upon inspection it looks like some of the parts have been used, I purchased a NEW set. Since it appears my set has been monkeyed with I just want to make sure I have the correct coring blades for the Micro. The blades I have fit into the large end of the handle. They will not fit in the small end. I am just guessing that the small end of the handle would accept the micro blades. If anyone has the micro set please let me know if I have the correct blades. The blade height is about 15mm or about 19/32" and they are about 3.02mm thick or 1/8"
If anyone can help me out I would appreciate it.
Tim.
Tim
I have the micro (and the small and regular) set. As I recall all the blades are the same "height" at the handle. At least they all fit in the handle. Actually I use the micro handle throughout.
The micro handles are thinner, and without going out and measuring, I would say they are the right handles, even more so if they are all the same size.
