Mahony Utility Finish
New Glarus, WI
Mahoney Utility Finish
Just received and used the Mahoney "walnut oil" finish on a piece of walnut. I'm quite pleased with the results.
Is this finish appropriate for use on most any kind of wood?
:confused:
If you're creating utility pieces for the kitchen, the species of wood is probably not limited by the finish compatibility so much as it is the properties of the wood (hardness, porosity, potential for allergic reactions, etc.).
It's a curing oil, acting pretty much as any other curing oil does. I use walnut oil on kitchen things all the time. Don't burnish and close the pores of the wood, and you'll get pretty good water-rejecting soak for the first coat. If you decide on a second, wait a week, or until you can't see a smudge from a hard-pressed thumb in the oil on the surface. Very important to wipe after fifteen/twenty minutes or you start collecting stuff like non-curing oils while it's curing. Don't handle a freshly oiled piece with unwashed hands even to move it aside to shell peas. Good black dirt is great out in the garden, but looks less so on maple.
Don't know what Mahoney does, but commercial use outfits extract the oil with solvent, leaving any traces of nut proteins behind, The stuff you get in the store is just pressed, and may have traces in it. For the phobic, makes it possible to get a reaction to the oil until any proteins are denatured. Chances begin as infinitesimal and go to nil, but someone in the prove the negative mindset is bound to mention it.
You can burnish and harden the wood a bit after the oil's cured, if you like, and get a pleasant lustre. When relatively fresh, it's a great look, too.
Mahoney's Oil
I just posted a picture here in the photo gallery of a Mesquite bowl that has been finished with Mahoney's Walnut Oil finishes. I have been using it for a few months with good results.
I have also been using Mahoney's finish. Have had good luck with it. It just makes the walnut plates I made stand out. One thing though is how come it will turn mahogany almost black? My DIL wanted a set out of mahogany so tried some walnut oil on a scrap. Didn't like the outcome at all. I have used it on maple which it darkened slightly but nothing like this.
I use Mahony Utility Finish a lot, But I use Mahonys Wax finish most of the time.It's easy to use, you just wipe it on, leave it to "soak in" for an hour or longer, then wipe it off, it leaves a nice satin finish that feels and looks great.
I like my turning to have a sheen but not a shine that hides the wood.
Thanks for the compliment, though I must say that he is one of a couple hundred I make each year, and selling for as little as they do, I have to keep the time per spoon down to ~20 minutes. Craftsmanship does suffer a bit under those circumstances.
Walnut oil is certainly more permanent than simple waxing, but after a few years and no renewals, it looks a bit different than it did when first applied. This is a '98 model.
