Lubricated sanding
Sanding with oil, wax, or other lubricants is very effective. Some people use mineral oil, some use a soft wax, I know some who even use WD 40. Water can be used, but it will raise the grain on some woods. My preference is the Tung oil that I use in finishing.
You'll find that you'll cut your sanding time almost in half. Sanding torn grain with oil and 80 or 100 grit will take care of the damaged area in minutes, and the wood will look like you'd sanded with 120 or 150 grit. Works great for hand sanding small damaged areas. I only use the oil for the heavier grits, but some use it for all grits. Gets too messy for me.
I'm not sure just why it works, but it does. It does soften the end grain tearout areas.
A definite plus in using oil is that it helps eliminate sanding dust.
I find that using oil when shear scraping, especially in difficult areas is very effective. I am usually able to start sanding with 150 or 180 or even 220 after shear scraping with oil.
I occasionally use wax as a lube. Primarily with tricky exotics that would otherwise crack because of the heat (Ebonys, Cocobolo, snakewood,Pink Ivory). the wax helps in keeping the heat down because of less friction. I saw it in a box making video.
The only problem I see with it is htat I use lacquer more often than not as a finish and the oils will interfere with the finish adhesion. With wax it will melt in, but final coats can have a problem.
A wax and/or oil or just about anything a little viscous (sticky, thick, etc.) helps sometimes. Now, what we're talking about here is wet sanding the WOOD and not wet sanding a FINISH applied to that wood. Completely different animals there.
A few different reasons for using it that are often cited...
1) Less heat - Heat is your enemy in sanding. You'll get some slipping, yes, with the use of wax but you'll also be able to prolong your sanding with less heat buildup
2) Less dust - This is obvious. Not really having to do with making your sanding more effective but just nicer to work at.
3) Helps with tearout and fuzzies - the wax fills the voids between fibers and tearout holes making things a bit stiffer so that the sanding (or even the tool usage) cuts off those fibers instead of just laying them over. It gives it more support, in other words.
4) Fills the grain - Can give the appearance (at least initially) that the wood is "denser" or more closed than it actually is. The wax fills the grain much like a sealer coat would. Of course, this can cause problems too (see below) but it's a quick way to fill very very tiny problem areas too.
5) Easier to see tearout areas - They tend to show up as dark blotchy areas.
And some problems with it....
1) Can interfere with your finish of choice. Wax, oil, etc. don't go well with other finishes. Sometimes, if it's an actual drying/curing oil, you can let it completely dry/cure and then use that finish when you couldn't have otherwise.
2) Fills the grain - This can "muddy" the appearance of some woods. Not usually a problem with burls though. I equate it to the effect you'll get with a slightly out of focus picture. You don't get nice, sharp, definitive looking wood. This is either good or bad depending on what effect you want to achieve.
3) Sandpaper loading - You'll quickly fill up your sandpaper with the wax. Some sandpaper is good at being able to be cleaned but many are not. Lots of ways to try to clean the gunk off but it usually involves messing up the sandpaper particles sufficiently that it's no longer acceptable to use. I usually reserve my sanding with wax/oil/etc. to the very very last detailing step (if need be) for this reason. Keep the sandpaper moving quickly to new/fresh areas of the sandpaper.
