light house night light
I have a couple of the old glass electric insulators and have seen a night light that has been woodturned with the insulator as the globe. Can anyone direct me to a site that would give me some help on turning this?
Rod,
You did not mention your experience level.
First you'll need a small foundation in spindle turning and face grain work.
make a connection with an AAW chapter near you.
http://www.woodturner.org/community/chapters/LocalChapters.asp
Then you'll need a plan. the process will be different depending on the lighthouse style you choose. A Chesapeake bay style like Tomas point light or one of the tall cylinders ones light those in New England or the outer Banks.
from the bottom up
1. base Consider a burl with the natural surface to give the illusion of a rocky island. or a wooden disk dyed blue for water.
2. structure a cylinder of wood to scale to match the insulator or spindles for pilings attached to an octagonal glue-up of segments for the thomas point style.
3. the light- your insulator
4. the roof
through the center you will have a hole from the base to the light fixture.
this would be the diameter of threaded lamp rod. the base needs and opening for the nuts to tighten the rod and hole to the side for the cord.
a consideration is the light. I'd suggest the led's because they generate very little heat. you will need to turn or drill a space to accommodate the fixture.
You may also wish to have your light turn, blink, or be focused. this requires a small motor, controller or mirrors these kinds of things can be found at the model railroad store. In fact this is the kind of project they might be happy to help you with.
Finally a wood burner can be used to create the bricks or the weathered boards
have fun,
..... a consideration is the light. I'd suggest the led's because they generate very little heat. you will need to turn or drill a space to accommodate the fixture.
That is really a thorough answer, Al. I had never thought about making a lighthouse, but I might give it a try since I have a few glass insulators. Any suggestions for the brown ceramic insulators that are used for the guy wires (not as common as the insulators for the current carrying wires).
I recently bought an LED night light at the local Ace hardware store and the the price is really low. They put out about as much light as the 4 Watt incandescent night light bulbs without generating the heat. Additionally, they have a light sensor to turn them off when the room lights are on. If you do not want that feature, it is easy enough to cover the sensor with black electrical tape.
