Over the years I have had a simple Rockwell Lathe, an old Walker Turner ($100) a General, and now a VicMarc VL200 VS Long Bed. This in addition to my Huge Production CNC Lathe.
My question to you all is:
Q: "IF you were buying a new Lathe for Spindle work and some average Bowl work, what lathe would you buy? Keep in mind that this lathe must be able to make Furniture parts, and decorative platters and bowls (not to exceed 16" dia).
Note... Powermatic does not count (made in Taiwan) nor would any other Offshore cheap lathe.
I'm looking for Top of the line machines that will last for Generations, are easy to use, comfortable, with readily available parts both now, 5 years - 50 years from now.
I might stay with a simple 4 step pulley system so as to avoid voltage issues and electrical problems too.
Thanks
Thanks
