Lathe and tool safety reminder
Austin, TX
www.woodturner.org
I've recently read about some accidents reported on other wood forums which occurred while working on wood in the last month. Many folks who are new to turning may not understand how dangerous turning can be. The related equipment like bandsaws, chainsaws, and other power tools are dangerous too. Every year people get hurt.
Please follow safety guidelines. Review the AAW Lathe Safety Guidelines
I do not feel that goggles or safety glasses are sufficient. If you get whanged on the head with a 5 or 10 pound piece of wood, you could lose an eye or even die. You should wear a face shield at a minimum. A lot of demonstrators do their demos without faceshields and that probably is not a good practice. I always wear a face shield, even when power sanding on a rotating piece. People even get hurt when wearing the correct safety equipment. It's not always their fault, sometimes things just happen.
Woodturning can be great fun. Safety equipment is not optional. You should protect your lungs as well.
So far I've been careful and lucky. My biggest accidents are scrapes on my legs from moving logs or whacks on the hand from a mallet (self inflicted).
One of my teachers stressed safety from the point of view: If he got hurt he couldn't work and would have no income. If you turn for fun you can't have too much getting hurt.
Jeff is right about the lungs. Wood dust is the number 1 hazard with woodturning. The wood dust effects build up. I Wear a respirator helmet most of the time and dust masks when I'm not wearing the helmet.
Another Caution. Two turners I know got serious injuries from the bandsaw.
Never push any part of your body toward a blade.
The tool you are using is the most dangerous one. Hand chisels can do serious damge too.
happy Turning,
Another thing for those of you in the colder parts of the country to remember, make sure chimneys and exhaust vents are clear before firing up heaters in your shops. I remember a woodworker (not a turner) in NJ being killed by carbon monoxide fumes the first time he fired up his heater in his shop one fall.
JimQ
In Phoenix, where it's still 90.:D
