Lamp shades
Cowlesville,Western New York
Although I've turned my share of lampshades, I would now like to do it on purpose. I have a lamp turned by my father, before I was born, and would like to add a turned wooden shade.
Can anyone direct me to any pertinent information on the subject? Thought checking here first might be faster than the internet search route. Especially since this forum has folks that have turned just about everything I could imagine and some items I never would have dreamed of, e.g. cupcakes!:D
Jake, I haven't turned a lampshade and can't see myself doing so in the near future, considering my skills. One suggestion, however. Before you get very far into your planning, take the lamp to a lamp store and see what size and shape looks best. Good luck.
Peter did a demo at the latest AAW symposium and has a handout in the booklet. I haven't looked it over but will do that when I get home. I don't know if the information is online or not. If I finish downloading all the jobs I shot yesterday I'll try to look for some info. Here is his website.
http://www.woodshades.com/
Basically he just turns the first inch as thin as he wants. Places a light outside the wood so he can see what color it is on the inside. Then he turns the rest of the piece a few inches at a time until it all has the same color or translucency. That's the simple explanation. Wood species is pretty important if you want a really translucent shade.
Somewhere I saw a video...
...of a Gentleman who made them out of Aspen. They were end grain, and he basically turned a cone and used a hand saw to part it off. He used the same technique John Lucas described to turn them though.
If I were not at work, I'd find the video and link it....
Good luck!
I have turned several lampshades over the years, and there were 4 lessons learned.
1. ALL SHADES WILL CRACK from age, use, and the heat. Heat and dry wood will always be a problem if you use the lamp.
2. Aspen or a similar very stable, light colored, and relatively transparent wood is best for a lampshade because they can be used longer before cracking than other species, and there will be some stability from being able to turn them a little thicker.
3. Definitely use a lamp to determine thickness. Otherwise it will be too easy to turn the wood too thin. Also, it may not be uniform and the shadows in the thicker areas will definitely show, and the differences in expansion will cause cracks when the lamp is used.
4. Definitely use one of the new bulbs because they are cooler than incandescent. The lower heat will still crack the shade, but it will take longer.
Thanks guys, I now have enough information to be dangerous! :eek::) Some practice should give me a feel for how to proceed.
Sanding
I have not yet turned a lampshade, but when I do, I'll try to sand the inside and outside at the same time, so there's less imbalance of inward vs. outward pressure. It might be easier to get really thin that way.
Joe, I saw that tecnique demoed on hollow forms at Totally Turning this past spring. Thanks for the reminder.
I have a client looking for a wood turner to make a wood lampshade and lamp for her. Do we have anybody on this form who would want to take in on the project and perhaps have examples of previous work for her to see?
I've been interested in trying one as well. I met a guy way back when I was just starting into turning. He lived in a nearby town, and turned lampshades on a homemade lathe, that used half of a truck axle for the spindle and bearings. He said he used a chainsaw on his lathe to core out the inside somehow. I wanted to see it, but I had lost touch with him, then learned he had lung cancer and died, so I never got a peek at it. :confused:
Wood species is critical. Lighter wood is typically better. Anything dark is an occlusive (tannin, spalt, etc.) and will inhibit translucency. Aspen and poplar are good candidates.
I’ve heard of some turners using oil as a medium to help light pass through the wood (the same way the water in fresh cut green wood makes the piece more readily translucent than when it has dried). This can be done with several heavy coats or via an oil bath. I tried the multiple heavy coats route with a piece of flaming box elder turned to <1/8”. After several generous coats of T&T DO and a couple of weeks to cure, the shade was noticeably more translucent in some parts (particularly through the end grain), but still didn’t glow like I’d hoped. Going to try again with poplar and hope for a better outcome.
Ron Kent, who turned gorgeous translucent NIP work, used 40-50 coats of oil. His eponymous site is still extant: www.ronkent.com.
I have over the years tried lamp shades and as Russ F said they will always crack if you don't do something to reinforce.
LampCherryLilac.JPGThis one was made about 2002 and all 3 shades cracked.
This lamp made of red oak held up without the shades cracking until it was knocked off the table.
This white oak pendent lamp made in 2022 seems to have survived the cracking phase.
The backdrop for the photo is the CAD drawing of the chandelier for the MWA club project entry at the symposium in Tacoma Washington, but I can't say if the shades are still intact, because it was purchased at the auction.
Visit www.woodshades.com. Peter Bloch is in my view the authority on the subject, and you will see the remarkable work he has done. He also shows the process.
I used Peter Bloch’s methods to turn these, and other, thin items. The “egg box” is aspen, what Peter specs as the best wood for translucence. I dont remember the wood species of the other piece, may have been sycamore.
Turned to ~0.070” thickness, finished with minwax regular poly thinned 1:1, continually flooded on until absorption stopped. In testing I found the poly to actually let a bit more light through vs BLO due to it being a bit lighter in color.
lampshades, ...
As advised, you might turn them using the lamp to judge the evenness and thickness, as done by those who turn hats. Here's Chris Ramsey turning a cowboy hat at a club demo:
I have turned few lamps and shades, My experience has shown me that Aspen lets more light through, more than Poplar.
Also a clear log helps with even outcome, though I do like a bit of spalting in that shows then finished.
As for splitting that does not need to happen, maybe Russ did not use the LED or CFL bulbs as these give little heat unlike the incandescent ones we used to have for all types.
I have a lamp that gets used every evening, since 2008 with a CFL bulb in it, and no splitting.
