I've finally set up and started using my new bandsaw. It replaced a Delta/Rockwell 14" with 1 HP motor. I'm very pleased with the Laguna. The ceramic guides remind me of the "cool blocks" that came with the Delta. I can change blades in 10 minutes (I timed it). The ceramic guides under the table are easy to adjust even with my fat fingers. You can see what you're doing through the throat plate hole. The 3 HP motor plowed through some 10" thick walnut without hesitation. I wouldn't be without the foot brake. I was leaning toward the 14BX for that reason and decided this will be my last bandsaw so spent the extra for the 18. The extra large table is great for 50# log halves. I've used the 1" blade to saw some green walnut planks, the 1/4" to cut some round templates and the 1/2" for cutting some 8" thick walnut bowl blanks from 6" to 12" in diameter. The only issue I had with set up was the table tilt was rough. I removed the table and found the trunnion base had some rough debris in the milled areas. I cleaned it with 400 emery cloth, gave it a light grease and it now tilts very smoothly. It's only been in use a couple of days but so far I'm very impressed. All the adjustments are simple and stay true.
