This end grain sealer is about 1/3 the price of Anchorseal. Is it any good, or, do you get what you pay for? Thanks.
Thats what I do.Got this from Mike Mahoney, Use Elmers white Glue. 1 gallon on E-bay is less than $12 with free shipping. Mikes dilutes 1 gallon with 12 oz of water.
Brian, do you do the same dilution-12oz water per Gallon of glue? Thanks!Thats what I do.
More or less - I pour out about 2/3 pint of glue into a pint jar, top it off with water and shake it up to mix, then slather it on. I'd guess maybe a bit thinner than 12 oz water to a gallon - but my 2/3 :1/3 mix seems to work for me. Basically mixing water into the glue until it's about the consistency of a latex paint, I guess. (Thicker than mixing glue & water for joint sizing, but thinner than straight glue)Brian, do you do the same dilution-12oz water per Gallon of glue? Thanks!
I'm with you. I switched when Anchor Seal went to their "new formula" I have found that titebond #1 works great and as a bonus, I never run out of glue!I just use Titebond or Elmers glue. Both work fine. I have a couple of 'old' bottles, like the gallon size, and drown the surface you are trying to seal. No clue as to how they compare cost wise...
