Jet 1640EVS Lathe. Mint condition
Status
Not open for further replies.
Nebraska
Hey all, new to the forum. I have a Jet 1640EVS for sale. It’s less than three years old and was only used twice.. not a scratch on her. We moved and am currently building a new garage shop, but it won’t be done till early next year and I think after consideration I’m going to sell it so I can pay for the project. Wired for 110v but can be rewired to 220v. Lathe is basically brand new and in perfect shape so I am asking $2300. It’s on backorder though a lot of dealers and costs $2600 new. Pickup is in western Massachusetts.
JWL-1640EVS Wood Lathe is loaded with cutting-edge features that distinguish it from others in its class. Included is a sliding headstock, electronic infinitely variable speed from 40-3,200 RPM, and a newly designed headstock locking handle.
  • Sliding headstock
  • Extended spindle nose houses dual headstock spindle bearings
  • Improved tailstock quill locking mechanism incorporates an anti-rotation key
  • Tailstock features Acme threads for smooth and durable movement
  • Banjo uses non-marring, positive locking wedge system to securely hold tool post
  • Tool post locking mechanism designed for year of consistent strength
  • Spindle lock latch frees up both hands
  • Electronic infinitely variable speed from 40-3,200 RPM
  • 36 integrated indexing positions
  • Newly designed headstock locking handle accessible from front of lathe
  • Convenient leg-mounted tool holder
  • Inverter is enclosed for added protection
  • E Drive Inverter features a built in EMI filter
  • Conveniently located digital readout
  • Rubber tool mat on top of headstock
  • Specifications:
    Swing Over Bed: 16-1/2"
    Swing Over Tool Rest Base: 12-7/8"
    Distance Between Centers: 40"
    Spindle Height: 44-1/2" from floor
    Spindle Bore: 5/8"
    Tailstock Bore: 3/8"
    Spindle Taper: 2MT
    Quill Taper: 2MT
    Quill Travel: 4-1/4"
    Spindle Thread: 1-1/4" x 8 TPI
    Spindle Speeds: High range 120-3,200 rpm; Low range 40-1,200 rpm
    Speed Range: 40-3,200 rpm
    Number of Indexing Positions: 36
    Bed Construction: Cast Iron
    Motor: 1-1/2 HP
    Voltage: 115 V
    Recommended Circuit Size: 20 Amps
    Net Weight: 375 lbs
    Shipping Weight: 440 lbs
    Standard Accessories:
    14" Tool Rest
    Tool Rest Extension
    3" Faceplate
    Faceplate Wrench
    4-Prong Drive Center
    Live Center
    Revolving Cone Center
    Knockout Rod
Status
