Hey all, new to the forum. I have a Jet 1640EVS for sale. It’s less than three years old and was only used twice.. not a scratch on her. We moved and am currently building a new garage shop, but it won’t be done till early next year and I think after consideration I’m going to sell it so I can pay for the project. Wired for 110v but can be rewired to 220v. Lathe is basically brand new and in perfect shape so I am asking $2300. It’s on backorder though a lot of dealers and costs $2600 new. Pickup is in western Massachusetts.
JWL-1640EVS Wood Lathe is loaded with cutting-edge features that distinguish it from others in its class. Included is a sliding headstock, electronic infinitely variable speed from 40-3,200 RPM, and a newly designed headstock locking handle.
- Sliding headstock
- Extended spindle nose houses dual headstock spindle bearings
- Improved tailstock quill locking mechanism incorporates an anti-rotation key
- Tailstock features Acme threads for smooth and durable movement
- Banjo uses non-marring, positive locking wedge system to securely hold tool post
- Tool post locking mechanism designed for year of consistent strength
- Spindle lock latch frees up both hands
- Electronic infinitely variable speed from 40-3,200 RPM
- 36 integrated indexing positions
- Newly designed headstock locking handle accessible from front of lathe
- Convenient leg-mounted tool holder
- Inverter is enclosed for added protection
- E Drive Inverter features a built in EMI filter
- Conveniently located digital readout
- Rubber tool mat on top of headstock
- Specifications:
Swing Over Bed: 16-1/2"
Swing Over Tool Rest Base: 12-7/8"
Distance Between Centers: 40"
Spindle Height: 44-1/2" from floor
Spindle Bore: 5/8"
Tailstock Bore: 3/8"
Spindle Taper: 2MT
Quill Taper: 2MT
Quill Travel: 4-1/4"
Spindle Thread: 1-1/4" x 8 TPI
Spindle Speeds: High range 120-3,200 rpm; Low range 40-1,200 rpm
Speed Range: 40-3,200 rpm
Number of Indexing Positions: 36
Bed Construction: Cast Iron
Motor: 1-1/2 HP
Voltage: 115 V
Recommended Circuit Size: 20 Amps
Net Weight: 375 lbs
Shipping Weight: 440 lbs
Standard Accessories:
14" Tool Rest
Tool Rest Extension
3" Faceplate
Faceplate Wrench
4-Prong Drive Center
Live Center
Revolving Cone Center
Knockout Rod
