I have old tools from Sorby that test the same Rockwell as modern HSS steel . Can the Rockwell test indicate whether I can use the old tools on a new CBN wheel ?.
The old sorby orange kangaroo tools from 1974 do not have HSS stamped on the tools. I’ve been using them all this time , buts it’s the advent ofCBN for me that makes me question their use.Interesting. Does the Rockwell test measure metallic structure or only hardness?
I believe any Sorby listed as HSS is fine for CBN wheel.
I've had lots of Sorby's - both carbon type and HSS. I recently came accross my first HSS in the old style orange handle with Kangaroo label. I've always assumed the older handles were old steel.
More pertinent to your post, if you use not HSS on the CBN, it does not hurt the wheel, the weaker steel fills the wheel with particles which require cleaning to remove. Once cleaned, the wheel is back to new.
But not carbide, right?You can then grind any metal
Just buy the Slick Stick from woodturnerswonders.
within a month, there was no remaining metal left on the wheel to
He was referring to sharpening carbide on a CBNThat said, I would heed Robo's warning that using the softer steel will "greatly reduce" wheel life.
I use the diamond plates to touch my Carbide gouge tips and they work fine. But being plates I expect to replace them fairly often,luckily they are not expensiveWell, not positive, but the Rockwell hardness test determines hardness and so many other things can change that. Grinding a "softer" steel on a CBN wheel can result is some build up on the wheel. If you have other HSS or V10 or M42 tools, they do a good job of cleaning that build up off. I tried the Slick Stick on my CBN wheels and didn't like it, just too thick. It does work nicely for bandsaw blades to keep them from gunking up when you are cutting green wood, and it is the best thing I have found for the soles of my hand planes, by far! I did have one old CBN wheel that was nearing retirement age. Just out of curiosity, I ground some soft steel, aluminum, copper and brass on it. There were visible lines on the wheel after. I went back to normal sharpening and within a month, there was no remaining metal left on the wheel to the naked eye. I have used the Trend lapping fluid on my wheels to help prevent build up. If you put the drops right on the wheel, stand out of the line of fire for a bit since it will leave you with a racing stripe on your shirt. I use a drop or so on the bevel of the tool I am sharpening. As for carbide, it can be done on a CBN wheel, but you will GREATLY reduce the life of the wheel. Diamond wheels or lapping plates only. There are diamond plates up to 8000 grit now days. No clue how they would work on the carbide tools since I have none of them in my shop.
I generally regard old tools as not being HSS, especially if there is no markingsI have old tools from Sorby that test the same Rockwell as modern HSS steel . Can the Rockwell test indicate whether I can use the old tools on a new CBN wheel ?.
I have access to a tool and die shop professional tester and they both came up with 60 Rockwell but one sparks and the other no.I grind both HSS and high carbon hardened steel on CBN with no problems.
The thing about non-HSS is don't get the edge hot enough to turn blue or the hardness will be compromised.
A water wheel, such as the Tormek, is perfect for sharpening them.
With a normal CBN wheel, grinding hardened non-HSS gently and cooling often won't load up the wheel. At least, I've never had that happen.
If a hardened tool is not marked HSS, I treat it as if it is not HSS.
You can get a HSS edge red hot while grinding without damage (when glowing read just don't cool rapidly with water)
You can even use CBN wheels on non hardened steel or low carbon/mild steel without loading the wheel if you grind gently. I do this often on the flat sides a CBN wheel when flattening part of something such as a screwdriver.
Considering old tools, this has been mentioned before but some in my "old tools box" have not been hardened and some have only been hardened for the first few inches from the tip. Test with a file. I use a small triangular file - if the file "skates" on the steel, it's hardened. If it removes any metal (files a small groove) it is not hardened. When I find tools like this I mark the hardened length for future reference. (Old lathe tools with handles are great for shaping into custom, special use tools.)
Note: for determining the type of steel look up spark testing. I use spark testing most often to identify true wrought iron when I find unknown pieces around old barns.
Mark, do you have or have access to a Rockwell hardness tester? Or are the numbers the advertised numbers?
I used to use one in the lab but don't have access now. I'd love to have one but they're a bit expensive.
Has anyone tried the hardness testing files, such as these (I'm thinking of getting a set)
There is a little video on the page which seems helpful.TSUBOSAN Japan-Hardness Tester Checker File HRC40-HRC65 Set of 6 - Amazon.com
TSUBOSAN Japan-Hardness Tester Checker File HRC40-HRC65 Set of 6 - Amazon.comwww.amazon.com
For $18 more you can get one with instructions in English...
Edit: I wrote this earlier and forgot send it till now. I didn't see David's msg about the overheating, sorry for the repetition.
I wanted to measure the inside angle of Hunter cupped carbide cutters. I ground 1/4" off of a 1/2" hunter carbide cutter. Did not hurt my Dway 180 grit wheel. Of course you wouldn't want to grind the top of a flat carbide. I have also sharpened concrete drills that are carbide tipped..But not carbide, right?
Do you use this also to clean the CBN wheel or is there something else? Thanks.
No carbide involved in my question. Just can I sharpen the tools that show sparks on my new CBN wheels without permanenly damaging the wheels as they were expensive. Most of my tools are stamped HSS and even they show sparks some not. I think I’ll just go ahead and not worry about all the warnings. Thanks all for your commentsI wanted to measure the inside angle of Hunter cupped carbide cutters. I ground 1/4" off of a 1/2" hunter carbide cutter. Did not hurt my Dway 180 grit wheel. Of course you wouldn't want to grind the top of a flat carbide. I have also sharpened concrete drills that are carbide tipped..
Well going back over the thread, I see that no one has really answered your questions - most of them just talked over ya. Rockwell test for Hardness would tell you next to nothing about what sort of steel you are grinding (Which is what you really want to know about for CBN Wheels) Rockwell can just tell you how hard your steel is, whether it is M2 HSS or High Carbon (You could probably get a identical hardness test on either type steel!)No carbide involved in my question. Just can I sharpen the tools that show sparks on my new CBN wheels without permanenly damaging the wheels as they were expensive. Most of my tools are stamped HSS and even they show sparks some not. I think I’ll just go ahead and not worry about all the warnings. Thanks all for your comments
not carbide which is too hard for CBN)
Sometimes seems there are exceptions to everything, including conventional wisdom.
I might not sharpen carbide wood lathe tools on CBN. However, I have a friend who after trying my fine CBN wheels, bought one for a bench grinder just to sharpen certain carbide bits for his metal lathe. He said he uses a light touch and I think mechanical support and said it works. He uses a microscope to evaluate the before and after sharpness. I've never watched so I don't know if he does anything special. IIRC he's used it for 4-5 years now.
Diamond wheels would be better for carbide but are not appropriate for sharpening carbon-based steel, also important for metal turning, at bench-grinder speeds.
I have one of those orange handle Sorby tools and it is clearly marked as HSS
It was originally a parting tool with the coved top and the tapered body so that the bottom edge was about 1/2 the width of the top. The original configuration was capable of a cleaner cut then a conventional parting tool but it was almost guaranteed to catch and destroy the work piece.Cool. This is the second HSS in Orange I've seen. Apparently, Sorby began offering HSS before changing handles. Having seen so few of them, I suspect it wasn't offered for long.
Can't see the business end of that tool, what is it?
Also - has anyone ever seen a Sorby carbon steel in their new handles?
Sorry if this wavered from the original post.
The one that I have I think I bought it to cut the square to round on the balusters for the stairway to the second story that I added to my house in about 1972-3. The tool didn't work as advertised but I did learn to make the cut with the long point on a skew.There are 5 orange kangaroo gouges and scrapers circa 1975 all of them not marked HSS. I have inspected then carefully and they test 62 Rockwell and marked Sheffield steel UK. I’m the original owner and used them all these years. I’m 95 old
I've been looking for this answer for so long. I live in the very south of Argentina and have wondered for some time now if carbon steels that were hardened to about HRC 62 could be safely ground on my CBN without messing it up, since I'm not finding a replacement down here any time soon.because of the nature of how it cuts, it can clog up when grinding High Carbon steel (because the metal in sparks can be hot enough to melt and turn into hard smooth slag on that microscopic level)
you should be fine - *IF* - Big IF - you take care to not grind heavily - CBN wheels are better suited to "sharpen or hone" (light grinding) and not well suited for shaping (I.E. grinding an old file from a square end into a skew), you'd be better off doing that on a normal aluminum oxide grinding wheel... However once you do have your tools shaped and ground to the bevel and shape you want, then by all means a sharpening on CBN should give you no problems.. as I mentioned just take care to not grind heavily or let tools get too hot on the wheel and they likely won't "melt" into the CBN...I've been looking for this answer for so long. I live in the very south of Argentina and have wondered for some time now if carbon steels that were hardened to about HRC 62 could be safely ground on my CBN without messing it up, since I'm not finding a replacement down here any time soon.
I have a spindle roughing gouge made with a piston pin witch works wonders, but I've kept off my CBN fearing to harm it in any way. Not sure what steel or hardness of the piston pin is, but I presume it will be the same case as what you mention, where it will melt and clog up my wheel.
Anyone knows what the case is with grinding files on a CBN? (I know files are brittle and not recommended by many, but we've got little to no tools in Argentina so many people here rely on old files, mainly as skew chisels, where there is little to no overhang anyway, so the risk of it breaking is minimal)
Marc, if you are still watching this thread, here is a bit more info. I inherited 8 Sorby scrapers from my father, who bought them in the '70s. They are not marked HSS, but I can easily tell from the spark pattern that they are HSS. I sharpen them on my CBN wheels and they do not clog the wheel or cause any other issues.There are 5 orange kangaroo gouges and scrapers circa 1975 all of them not marked HSS. I have inspected then carefully and they test 62 Rockwell and marked Sheffield steel UK. I’m the original owner and used them all these years. I’m 95 old
Thanks. My tools are all shaped by now, so I'd only do the usual touch up. I'll keep your advice in mind and do any reshaping on an aluminum oxide wheel.you should be fine - *IF* - Big IF - you take care to not grind heavily - CBN wheels are better suited to "sharpen or hone" (light grinding) and not well suited for shaping (I.E. grinding an old file from a square end into a skew), you'd be better off doing that on a normal aluminum oxide grinding wheel... However once you do have your tools shaped and ground to the bevel and shape you want, then by all means a sharpening on CBN should give you no problems.. as I mentioned just take care to not grind heavily or let tools get too hot on the wheel and they likely won't "melt" into the CBN...
I've read that thread a few days ago, it's very good information! I think he sharpened copper on an old CBN wheel and managed to clean it up with HSS.Years ago Robo H wrote about some tests he did - if I remember correctly he found that sharpening HSS tools could help clean up a clogged wheel.
Good to read positive experiences from other people. My first gouges were absolutely terrible carbon steel tools that would go blue just by looking at them, so I developed quite a skill of sharpening without overheating, even with a high speed grinder and aluminum oxide wheels.I've had a cbn wheel for over 5 years, sharpening both HSS turning tools and bench tools like chisels and plane blades with no evident problems. I use an aluminum oxide wheel for major reshaping. Cbn runs a lot cooler but no matter what wheel is used overheating will destroy the temper on high carbon tools. You can lower the heat with something like this. coolant sprayer
My CBN is from WoodturnerWonders and I did get some Slick Stick with it. I thought it would be a good idea to apply some of it on the new wheel before even using it, to prevent any possible build up, but I seem to have added way to much and gunked it up. Seems like I actually achieved what I was trying to avoid.If you get the Slick Stick from woodturnerswonders and treat your CBN wheels with it you can grind quite soft metals on CBN without cloging the wheel. I've even ground aluminum just to see what happens. It doesn't hurt a thing although I would not recommend doing that. I've sharpened a lot of Carbon steel turning tools on my wheels without clogging after treating it with the Slick Stick.
Bill, can you define, or give examples of, "lesser steel"? Pardon me for feeling this way, but that statement comes off a bit condescending. I find absolutely no issues sharpening M2 (typical Sorby, Crown, and other historic brands) and M42 steel tools on either CBN wheel I own, and I think, based on reading a history of your posts, those may be considered by you to qualify as lesser steel available to woodturners.I myself would never sharpen lesser steel with those CBN wheels.
