Congratulations to Scott Gordon for "Orb Ligneus" being selected as Turning of the Week for January 20, 2025
(click here for details)
Rough turn the cylinder.
Use two off center Centers about a 1/2" from the true center.
The best centers to use for this are cup centers with a point for the drive center and the tailstock center.
On each center I like to do a pull cut with a side ground gouge.
When both sides are turned for a tools handle you can sand on the true center since rounding the sharp corner is desirable.
Also for a tool handle you can do a modified oval. Use one of the offset centers on the tailstock sides and just turn one face. This gives a sort of flat on one side and the normal curve in the other.
