- Joined
- Jan 31, 2009
- Messages
- 137
- Likes
- 0
Today was day 2 of getting to play around with making a hollowing rig. The first day was nothing to talk about because all I did was go buy some steel for the project ($65-$75.00). But not all of it was meant for the hollowing rig. I made a 1" tool rest and fixed a broken welding cart with a couple small pc's and replaced the 5/8" axle (Pictures below). I picked up the welding cart and tanks for $50 (garage sale). Ok, so I started by laying out how I was going to make it on paper (using some of Stuart's pictures for reference) with measurements and cut up alot of the steel with my chop saw.
Today - Day 2 - I used a 110v, flux cored mig welder to tack the pc's in place so I could assemble most of it. The welder is weak honestly but it worked for now to tack it up - later when i get a torch set ill finish up the welding in a better way. The frame is 1 1/4 tube steel and I made a coupler out of 1" solid core that has a 3/4" hole drilled in it that I can slip in and out of the 1 1/4 tube steel - other end will hold a 3/4 solid goose neck tool.
I had a friend at a shop put a couple nuts on it and tap it and figure out how I want to do the tip for cutters.
Everything else i drilled and tapped myself. I used 1/4" small bolts for the holds and ground flat areas on the rounds to help keep it from slipping. Later ill add 1/4 nuts tack welded in place and drilled and tapped.
The goose neck is 3/4" solid cold rolled also and was heated and bent into the same configuration as the one I bought from Monster Tools. A flat area ground for the tip "almost" to the half way of the bar. I still need to drill and tap it. I still have more work to do on the laser and other parts so ill post more as i complete it.
Picture 1 - Rest 1" solid round
Picture 2-4 - Beginning of the hollowing rig assembly
Picture 5 - old and new welding cart with new axle and wheels from Harbor Freight
Is it a fun project ? Yep, but I have had alot of small headaches along the way and trips to the hardware store etc....
Will it work well ? Stay tuned....................LOL
Comments or suggestions ?
Thanks Dan
Thanks Dan
