Any plans or ideas floating around for something unique/interesting to hold a gift card that you could set in a cup holder?
Other than a lidded box.
I make Recipe card holders, which are essentially bud vases without the drilled holes - instead the tops are turned finial-like and then a dovetail saw (.030 kerf or so) is used to cut a slot through middle of finial to hold recipe cards - the slot is cut deep enough to allow the wood to flex just slightly as the card is inserted/removed so the kerf grips the card stock fairly well. They can be turned in pretty much any design you can come up with, I imagine.Any plans or ideas floating around for something unique/interesting to hold a gift card that you could set in a cup holder?
My brain is seriously broken tonight and combined with a migraine I can't understand why set a gift card holder in a cup holder? As a surprise for someone to find?
Cruelty? you're talking to a guy who one time filled a box with expanding foam then while wet I dropped $50 worth of quarters into it, let harden and gave it to my niece for Xmas when she was maybe 10.How about half an idea. Route a space in the flat side and end of a block of wood so that it is about 3/4 of the card’s face.
Glue a block to this face to make a slot to hold the card with a 1/4 sticking out. Then turn anything you like.
Card can stick out the side, the top, be square to the edge our at an angle
You might turn a cover for the exposed 1/4 of the card.
If you are into cruelty you can lock the lid on with type of puzzel opening. Lot of string puzzels cab be adopted for this
Or the whole container could be a cryptic type box opened with her name or birthday - there have been articles in the AAW on construction
Naaa I think more of my sister than to do that..Could do the same with gift cards.
