thanks Bill, but
If you add two matching, and opposing, wedges to each stack of planks, you can micro-adjust the height of the workpiece.
Joe's suggestion worked really well and
Once the ends of the log are cut as square a possible, screw the faceplates onto the log, but do not tighten the screws tight. Leave them perhaps a 1/4" loose. Mount the faceplate onto the spindle, supporting the opposite end with suitable props, and tighten the faceplate onto the spindle. Screw the tailstock faceplate onto your live center. This will have the log between centers, with the faceplate mounting screws loose. Do not try to run the lathe at this point. Snug up the faceplate mounting screws, paying attention to any gaps that exist between the faceplate and the end of the log. Where gaps exist, a well fitting shim will be needed in those areas. When all areas are perfectly shimmed, finish the tightening of the faceplate mounting screws. The use of long hex head lag bolts for faceplate mounting is strongly suggested, and doing the in-place tightening with the log mounted should be possible with a box end wrench.
Dale's directions worked, when you get it squared up it just screws onto the spindle like a three inch bowl blank.
unforturity, after trying two different spots to locate a spindle steady, i was starting to get vibration at 90 rpms. that being the case, and remembering what my 1st bowl attempt looked like, i have started removing the bark by alternate means, i do not believe Dixie Biggs will feel threaten by my effords, and i have a
July 10th - 10am to 12 - at PAA's classroom.
Figure Study by Roland Guidry.
Bring a sketch pad and pencil.
Everyone welcome. Whether you are a beginner or advanced writer, quilter, painter, sculptor or painter, everyone will benefit.
Hope to see you there.
Iris Gillispie
so i am going to try to get free sculptor ideas tomorrow.
the punky wood at the bottom and being aligned where i had to take too much wood away from cyllinder/trunk for spindle steady makes mm statement very real.
Stand clear, rest near, and cut the wood as it wishes to be cut.
this was/is a learning experience and watch out Dixie/Mark, i have been at the bottom of the learning curve before, it really is fun to look back and see improvement. btw, when turning uneven spindle in this case a small toolrest is mandatory.
