Hi
I’m ready to pull the trigger on upgrading my 3520c with a Oneway banjo. The stock 3520 banjo is 5 3/4” tall. The 20” Oneway banjo is 7 1/2” tall, while the 16” banjo is 5 1/2” tall.
I’m guessing that Oneway uses a taller banjo because it’s more rigid. This sounds good, but the downside is it limits which tool rests will fit. My 14” power matic tool rest is too tall. My robust tool rests would work, but not the large inside rest I was thinking of buying from robust. I would need to replace my 14” rest with the oneway version and get the Oneway inside bowl rest.
The 16” Oneway banjo would not work with “regular post” robust rests, but works with the “long post” rests. From this I assume that the Robust banjo is taller than the 3520 but shorter than the 20” Oneway.
So I think it basically comes down to 20” banjo is probably more rigid, but won’t work with some tool rests.
What would you do?
What would you do?
