help ideaing these angles
Does anybody know what these angles are called and how to lay them out? I had a link explaining everything about them but pc crashed and I lost everything.
Thank you
Tom
Thank you
Tom
The image is hardly any larger than the thumbnail. Do you have a larger version that you could post?
A magnified screen capture (Print Screen Key, msPaint Paste) indicates on-screen measurement of about 1" diameter for the upper ring and 3" for the lower. There appear to be 6 divisions, with the lower end of the fins offset by one division (which may be just by chance). The vertical dimension is immaterial.
A quick and dirty plan view sketch indicates that the fins are approximately tangent to the upper ring.
"Tangent" might be the term you seek. Adjust the dimensions of the two target diameters and choose the number of divisions. Each tangent is perpendicular to a radius at each point on the upper ring.
If you force the offset instead, the fin might not be tangent, but it might not matter.
From looking at the pic on the iPhone it looks like compound angles to give the illusion of a slight curve.
Tom, there several ways to accomplish this type of effect. The simplest would be to cut "simple" (not compound) mitered segments from over-sized material. The trick is to cut all the angle on just one side of the segment. For example, if a normal segmented ring were constructed with 8 segments, each side of the segments would be cut at 22.5-degrees. To achieve this twisted effect, you simply leave one side at 90-degrees and cut the other sides at 45-degrees. When the segments are squeezed into a round ring, they will slightly rotate and create this type of effect. Hope that all makes sense.
Thanks for all the help. I think I understand the concept now . and thanks for the link that was just what I was looking for plus found another forum to look at.
try this link to "turned by george"
check out his segmenting gallery page they look similar
i believe he(or maybe someone else) posted here a few years ago
but couldn't find that info.
http://turnedbygeorge.com/id66.html
IAN
Ian,
I obviously didn't read all the way down before making my initial post.
Thanks for the shout out!
G
