Headband magnifier
Palm Coast, FL
www.syzygywoodworks.com
Can anyone recommend a good headband magnifier? I have the one from Harbor Freight and it works fine, except that I have to hold the work a couple inches from my face. I'd like something where I can hold the work at a more comfortable distance.
Thanks.
Thanks very much for the replies and the links. I didn't realize the focal length was related to the magnification.
Hello Keith.........
I have the Optivisor LX-5, 2.5x power, 8" focal length.
Not sure what your intentions are, but I'm not using mine as much as I thought I would. Pretty much only for use while inscribing detail grooves in my bowls.
I should wear it when grinding lathe tools, but have been a little hesitant because I ruined one pair of standard "glass" lensed glasses that way!
The closer the focal length, the more magnification. I'd rather not get my eyes 8" away from my work, but it's necessary sometimes. The Optivisor seems to be well made, and at the proper focal length distance, things look pretty clear. I wear the Optivisor over the top of my regular glasses.
Optivisor
I have these and wear them all the time. I position the lens just above my line of sight and flip them down whenever I need magnification. I also wear a set of prescription safety glasses with side protection. Being mostly a small item and spindle turner I feel safe. However, I don't think I would wear the Optivisor continuously if I turned large items such as bowls, but would opt for a face shield until I needed magnification. I believe the standard lens I use is either 2.0 or 2.5.
Regards,
Matt
Keith:
You may want to look at the "Mag-Eyes" magnifier as a fairly inexpensive solution. I know that Bonnie Klein uses them a lot for her small scale close-up work (she almost never took them off during the hands-on class I took with her several years ago!), and on her recommendation, I bought a pair to try. At our local Hobby Lobby store, I used a 40%-off discount coupon and paid about $ 19 - it comes with one standard lens (1.6X I think??) and two higher mag lenses; other lenses with higher diopters are available separately. For my uses, the mag Eyes worked well, so well in fact that I bought another just to have in the house for general use. There are now two different kinds - the original which holds onto your head by spring tension of the head strap, and another kind which uses a flexible strap with velcro to adjust and hold the headband to fit. See this link: MAG EYES
I also bought a bench mounted circular magnifier (6" diameter) with twin fluorescent lamps (via eBay) which has a much larger field of view and reasonable magnification, focal length, and depth of field. I nearly always use this magnifier for signing my work, as well as precision carving, etc.
For doing small work at the lathe (e.g. all detail work), I wanted something better than the Mag Eyes (...and Optivisor, which I also borrowed to try), I "bit the bullet" and bought a pair of eyeglass-style frame-mounted optical loupes (each lens independently adjustable for differences in each eye, interpupillary distance, etc.) which gives me excellent magnification, reasonable working distance, and acceptable depth of field. These loupes are often used by dentists and dental hygenists; pricier versions are used by surgeons, etc. Mine set me back about $140 (via eBay from a US supplier) - you can find them for more or less money than this, but at the recommendation of my dentist, I went with the model that has worked well for them, and found these loupes to be an excellent investment.
Given my background in science, particularly when using microscopy, I value the ability to see small things clearly, and as my eyes age (...along with the rest of me!), it is important to add whatever aids to vision are necessary to make sure one can see the necessary details. This results in better quality work with much less eye strain.
I am now toying with the idea of adapting a dissecting microscope on a boom to work on very, very small turnings, not unlike what John Lucas has done with the turnings of his micro-goblets (still waiting for the captured-ring on these!); this is not just a technical challenge with seeing well while cutting, but also having to develop fine motor-skills to control the turning tools while working on very small objects!
Good luck with your purchase!
Rob Wallace
Optical loupes
Hello Rob,
Could you please tell us the brand and model name of the optical loupes that your dentist recommended? As my vision declines with age, I've been upping the diopter strength of my bifocal safety glasses, but do not like the fact that with higher diopters comes the drawback of needing to have my eyes closer to the work. If the optical loupes allow the user to stay farther from the work, then I'd consider buying a pair.
Thanks for your time.
John
I looked at the optical magnifiers the doctors and dentists use. they are really expensive. If you had to wear them all day I think they might pay for themselves but if not the $20 variety work really great. I've worn my cheapies ()like bonnie Kline's for many hours without problems.
