In the CBN wheel discussion Bill Boehme wrote the following about a very slow to ramp up grinder:
How does installing a different microfarad rating cap affect the motor?
I have an old(er) Delta 8” slow speed grinder that has been discontinued. It’s a beast of a machine but it seems to need more than its share of capacitors over the last 16 years. I’m now looking at #3. The grinder is once again hesitating on which direction to rotate when switched on. I have only replaced capacitors with the same rating as the previous. Any advice?
My guess is that the start capacitor is on its way out. <snip> It should have the capacitance (in microfarads) and working voltage marked on it.
