If you are part of a club, you can probably find several mentors who can help. If not part of a club, join anyway since you can learn so much without having to figure it out by yourself.... Did that till we had a local club form. As for tear out, in side grain/bowl orientation, there is always tear out from going with and then against the grain when you cut, and there are 2 spots that tear and 2 spots that are clean, and they are opposite each other from inside and outside. The idea is to reduce it to the point where it can be fairly easily sanded out. On the outside of the bowl, finish cuts go from the bottom to the rim. On the inside of the bowl, you go from the rim to the bottom. Some woods to tend to tear more than others. With dry wood, you can wet the fiber and then very gently cut off the wet part. With green wood, first suspect is a dull tool. Second suspect is pushing too hard for your finish cuts. Roughing cuts don't make much difference since you are going for mass stock removal, but my roughing is much smoother shall we say, after many years. When you take a finish cut, you take very light cuts and don't cut faster than the wood wants you to cut. This means that your feed rate slows way down for finish cuts.
