In particular detail gouges. I have two detail gouges a 1/2” and a 3/8”. I have had the 1/2” for a while and when I first got it the end was very pointy and I couldn’t use it. Not sure of the original grind angle, but I now have about a 45 degree angle and I can use it now. I recently bought a new 3/8” detail gouge and the angle is about 30 degrees. Not pointy, but I get more run back than I like. I see the end is more blunt than the 1/2”. Should I keep trying to master this gouge,regrind to a sharper point, or change the angle? Also am I loosing the effectiveness of a detail gouge with the 1/2” ground at 45 degrees? Additional pictures show my other gouges and I can use them fine, but comments welcome.
Detail gouge
Bowl gouge
Spindle gouge
Detail gouge
Bowl gouge
Spindle gouge
