Goor or Bad for a Project?
Tupelo gum tree
Hi Cwearing,
Please understand I have never turned Tupelo gum tree but let me fingers do the walking on the internet. It appears it is in the Dogwood family of trees. That's a good family to be in as I have seen countless beautifully turned objects out of dogwood. I would go ahead and try it. What's the worst that could happen? You have a piece of firewood and some excess shavings on the floor. Good luck.🙂
Like the lady said, don't try to tie the two (of many) "gums" together. Sweetgum http://www.sfp.forprod.vt.edu/factsheets/sweetgum.pdf is one of the dirtiest domestic trees around if it grows in your yard, nicest-looking if you're driving past. Of course you won't have to clean up the mess from those things you're crushing ....
Black gum or Tupelo is a different critter entirely. http://ces.purdue.edu/extmedia/FNR/FNR-298-W.pdf Medium to light in weight for a hardwood, with interlocked grain, it doesn't machine well, though I would suspect, as with true poplar, that the market will see more of it now that we sell lumber sanded. As you can see, it's a secondary furniture wood, but makes great generic "wood" for crates, pallets and boxes. Pretty enough in a couple of its morphs to rate special classification in the lumber industry.
You might have some tearout on end grain, but because it has interlocking grain, it probably is less likely to crack than some other wood. It is not known for great figure, but what the heck ... turn some green and see if you like it.
I turned a couple of blanks of it. It turned pretty nice. You do need sharp tools for the final cuts. If it is free turn it.
