Flying saucer
Ottawa, Ontario
This is segmented in that it is two pieces.Each is turned separately as a bowl, of sorts, then they are glued up into one piece. It is about 9" in diameter and 4 1/2" high. Wall thickness is too thick at about 3/16". This one is cherry, stained with red sedona, then sanded so that most of the stain is gone. Finish is rattle can lacquer.
Comments and critiques are all welcome.
Jamie: For the interior, I sanded to 120 and applied a wipe on sedona red minwax stain. I just let it set for 5 minutes or so, then wiped it off. I sprayed two coats of rattle can semi-gloss lacquer over the stain. Then, I glued the two pieces together. For the outside, the end result is a "plan B". I had done the same stain routine on it, but only when the stain was dry did I see sanding scratches. So, I power sanded the stain off and started back at 120. When my wife saw how it looked at the point, she suggested that I leave it like that, rather than re-applying stain. So, I sanded it up to 600, then applied 6 or 7 coats of rattle can lacquer. (I get the lacquer from a local supplier that does up his own cans. When the weather is warmer, and for bigger pieces, I buy litres and spray with HVLP. This is solvent based lacquer.) I do not sand between coats of rattle can. The coats are so thin that, until there are 6 or 7 coats, I tend to sand through them. After the lacquer had dried for a week, I sanded very lightly with 400 to flatten the surface, then buffed with Beall buffs, using white diamond and hard wax.
Bill W: tks for your kind remarks.
Bill B: The grain match is largely luck. Ideally, these are done by starting with a thick block that is resawn. That way, the two pieces are book matched. I couldn't find a thick piece in my budget, so I just bought a cherry board. It was about 9" wide, so I cut two 9" lengths from it and turned them. I was lucky with the grain match.
Jamie: For the interior, I sanded to 120 and applied a wipe on sedona red minwax stain. I just let it set for 5 minutes or so, then wiped it off. I sprayed two coats of rattle can semi-gloss lacquer over the stain. Then, I glued the two pieces together. For the outside, the end result is a "plan B". I had done the same stain routine on it, but only when the stain was dry did I see sanding scratches. So, I power sanded the stain off and started back at 120. When my wife saw how it looked at the point, she suggested that I leave it like that, rather than re-applying stain. So, I sanded it up to 600, then applied 6 or 7 coats of rattle can lacquer. (I get the lacquer from a local supplier that does up his own cans. When the weather is warmer, and for bigger pieces, I buy litres and spray with HVLP. This is solvent based lacquer.) I do not sand between coats of rattle can. The coats are so thin that, until there are 6 or 7 coats, I tend to sand through them. After the lacquer had dried for a week, I sanded very lightly with 400 to flatten the surface, then buffed with Beall buffs, using white diamond and hard wax. [Snip]
Thanks, Grant. I'm practicing lacquer on a not-so-round bowl today, have done four coats so far. Will do two or three more before I buff. I'm using Deft for the time being (semi-gloss). Do you buy your HVLP liters from the same supplier who makes up the cans?
Bill W: tks for your kind remarks. Bill B: The grain match is largely luck. Ideally, these are done by starting with a thick block that is resawn. That way, the two pieces are book matched. I couldn't find a thick piece in my budget, so I just bought a cherry board. It was about 9" wide, so I cut two 9" lengths from it and turned them. I was lucky with the grain match.
The grain does match nicely. Funny how luck favors the prepared mind!
Another direction is to make one with mirrors inside.
Put an astronaut figurine in the bottom
It creates a sort of hologram of an object floating above the opening.
These were popular 5-10 years ago.
someone demonstrated making one at the AAW Symposium
Ron Browning had one at the Florida Symposium a few years ago.
Jamie: Yes, I buy the litres from the same guy. I'm lucky to be able to buy from him, as he generally only supplies the commercial shops. I took a class, taught by the owner, a finishing class at the local community college a few years back, and made a few pens for his business. So, now I can buy directly from him. I get stains, pre-cat and post-cat lacquer from him.
Al: I love the effect in that piece.
Tks, KO.
That looks really nifty. I've turned some pieces with a shallow spherical reflector ... not silvered, but with a high gloss CA finish. It does make a nice floating reflection image for ceiling lights and brightly lit objects. It requires a very high degree of precision to carry it off well.
