Finishing wormy wood
I just cut down my neighbor's nearly deceased apple tree. (Yes, I had permission:rolleyes:) After cutting into sections, I found a lot of it looked pretty punky but before tossing 2/3 of the tree, I decided to try turning a chunk and it made a very nice bowl. It's spalted, but not soft and punky after all. Plus, I turned it to finished shape right off and it barely moved.
Normally, I use tung oil and top with a little wax on apple, but the two pieces I've finished have many worm holes and grooves in them. Wax would seem likely to end up in chunks in the holes. How would you suggest I finish them?
Dean Center
Depending on the variety of wax, warm it so it flows instead of clumps. Hair dryer ought to do for it.
Thanks for the recommendations. I've got beeswax in citrus oil slush, Renaissance and a Minwax product. There are a bazillion holes in the 2 bowls I've finished and I would prefer not to have to clean out every one.
Dean
