I’m in the process of turning a decorative bowl made from laminated plywood scraps. So far it is coming along as I had hoped. The outside shaping is nearly complete. I notice that, due to the nature of plywood, there are a couple small, 1/8 - 1/4 inch voids on the edges. What do you folks recommend the best way to fill ‘em up? I was thinking maybe mixing some of my turned shavings with a bit of glue and pressing it into the voids before final sanding. But, what would be best - something like Titebond II or CA?
Thanks, Jim
Thanks, Jim
