Fein Vacuum
Emiliano Achaval
Maui, Hawaii
hawaiiankoaturner.com
I'm having a hard time locating a filter for my old Fein vacuum. I'm posting a picture of the model. It's not a cheap vacuum, I cant believe they do not keep selling parts for it... Thanks for the help in advance. Aloha
Fein has a parts break down listed under Turbo III (Wet & Dry Dust Extractor) parts section.
If you type Fein 9.77.25 into google their is a parts break down provided by a ServiceParts supplier.
Emiliano-
Is that the Fein Turbo II? I have the same one. If you're talking about the felt filter bag, I don't think they're available any longer. I've been using the disposable paper bags for a number of years, and I like them more than I did the felt ones. The paper bags don't clog with dust as quickly as the felt one did. I think the last time I ordered bags I got them from Rockler Woodworking. They come 3 to a pack. I usually order 2-3 packs at a time, just so I don't run out at odd times, You do have to install a cartridge filter over the center intake.
If you don't find anything Emiliano...I switched over to a Stihl, and it's a dynamite vacuum and the filters are both cheap and excellent. Maybe not quite as fine as the Fein, but amazing value for the money. The only problem is that you go to the chainsaw dealer to buy one, and that can get expensive! ;)
My fein still going strong, have the filter with duct tape... I'm determined to find one or I will make something... Sthil dealers are dangerous for our wallet! Aloha
Emiliano-
I was wondering why the bags come up when I search for the filter... That could be an option... Thanks!
I recognize that model number ... It is the older model Turbo III. I had one for many years until the motor burned up and I got a new Turbo III. The new Turbo III has a different model number (9.20.26), but the filters for both old and new models are exactly the same. So, all you need to do is get the filters for the new model number and you will be all set for more happy vacuuming.
I kept my old Turbo III for several years thinking that I would rebuild it, but believe it or not ... Fein repair parts are really expensive. I finally decided to say farewell to my old Turbo III during a City Clean Up Day last year. The new Turbo III has a few more bells and whistles and more casters so it won't tip over and it comes with a heftier price tag. The Turbo III's (both old and new models) are wonderful machines ... unbelievably quiet yet powerful enough to suck the hair off a bowling ball.
The only criticism of the new Turbo III is the three position power switch. Down is ON and middle position is OFF. The switch is stiff and the casters make the vac roll around easily so I wind up chasing the vac around the shop while trying to turn turn it ON and OFF.
You made my day! At the same time, I think I will call Fein again, I was told my vacuum was obsolete and no parts were available!! You think they would know!...
Greatly appreciated Bill!! Aloha
Here's the best deal on filters at Amazon.
I discovered that my new Turbo III is now obsolete so I better stock up on filters.
Tell customer support to give me a call if they need any help answering questions. :D
Someone mentioned that if I switch to the bags, I need some kind of filter.... So complicated... Thank you again...
So, you have been using the 5 micron felt filter? There is no replacement for it because the older Turbo III is smaller diameter than the newer version.
The paper bags are so much neater than dumping out the canister. They filter better than one micron, but you will also need THIS pleated filter. The pleated filter will last forever and doesn't get dirty unless the paper bag breaks (I have had a paper bag rip open once). Hopefully, you haven't misplaced the retaining hardware for the filter.
I wish I had a Turbo III. I have the Turbo II, and its a great vac, but sometimes I'd like the larger capacity. Mine is set up like yours, with the cartridge filter and bags. When I started using the bags, I never looked back. Yeah, they cost some $. But the filter doesn't clog up early as quickly. I've used it to vacuum up drywall dust, which is normally clogs up a vacuum very quickly. But with the bags, I can go all day without cleaning the filter.
Well, I have to do something, so I just bought the filter you showed me, I hope the bags are big... I like to just empty the dust and shavings around the yard, the bags I will have to throw away ... It's worth the try. If I misplaced the retainer, more than likely I did, lol, I will make an Argentinian contraption... Thanks again!
I used to cut the bottom of the paper bags open to empty the dust and then reseal it with glue and gorilla tape. Then I would use them one time too many and they would rupture. I usually just collect the dust and sweep up the shavings. I haven't tried a dust deputy, but I hear that they really work well.
Yes, I have ben using the filter that looks like a bucket
BTW, the parts for the pleated filter are the same for all of the Fein shop vacs so you can still get them unless you really want to do the Argentinan solution. In Texas we have the Aggie engineering solution that involves using baling wire to fix anything.
I just ordered everything... Tomorrow I will check to see if I have that locking piece... Might have to buy the part, lol...
I have a Dust Deputy, or whatever Rockler's version is called. It works very well and keeps almost all of the sawdust out of the vacuum. And the filters don't get clogged so quickly. I use it with my bigger Craftsman shop vac when I'm running my thickness planer or portable table saw. It has outlets for 2-1/2 " hoses, but I'm sure there's adapters to use the Fein small hose. I have the Fein 2-1/2" hose, so I'm set.
The industry standard size for shop vac hoses and brushes seems to be 2¼", but all of the Rockler stuff is 2½". I haven't found any adapters, but I can force fit the hoses and brushes together. I like Rockler's flexible anti static hose, but I wish that it had swivel couplings like other hoses.
You're right. My Sears vac hose and the large hose for my Fein are both 2-1/4". That's what I get for trusting my memory. :-)
Both hoses fit well with the Rockler dust separator. They slide right inside the coupling fittings.
On the Felder owner's group there was a comment about how the Mirka Vacuum was really a Fein. Call Fein and ask if the Mirka filters will fit yours.
Great suggestion! Thank you, I appreciate you taking the time to answer. Aloha
Funny, I was already thinking how to reuse the bags... Now, I dont know...
You're OK as long as you only reuse the bag one time less than when it would have ruptured if you used it once more. :D The old bags seemed to be tougher and could be reused until they were too small. After a couple bad experiences with splits and leaks I quit reusing the new bags.
I need to take a couple pictures to show how to install the bags. If you're not careful it's easy to tear the bag when pushing it over the air intake fitting.
Please do so Bill, I believe they arriving anyday now... Silly question: is the capacity of the bag as big as the whole receptacle? Bags look smaller than the available space.... Aloha
The capacity of the bags is a bit smaller than the total volume. The bags have to be smaller than the opening at the top of the canister or else you wouldn't be able to remove them without tearing. Also the pleated filter takes up some volume. I can say from personal experience that if you overfill a bag it can be difficult to remove.
Here are some pictures that might help to show how the bag and filter are installed. In the first picture the bag in my shop vac is about half full. When a new bag is installed the long end hangs straight down and across the bottom.
Holding the bag by the cardboard, push it onto the air intake fitting as shown below.
Resist the urge to push or pull on the bag itself because that can cause the bag to tear and cause you to say bad words. Push the bag as far as it will go onto the intake fitting.
Next, install the one micron pleated filter. The picture below shows the float valve (center), filter (right), and the cover plate with locking knob (left).
The picture below is a close up of the keyway that engages the key on the locking knob.
Next is the filter in place around the float.
One accessory that I really like is the basket that fits on top that also keeps the hose tidy. For some unknown reason they discontinued it.
Thank you Bill! I got the filter and bags today. Perfect timing. But, after seeing your pictures, looks like I need to buy the part that holds the filter.... I'll check in the morning and see if I pull an Argentinian Macgyver trick... I really appreciate you helping me out on this. The bags are big, they look small when you see them on Amazon... Aloha
It happens every time ... I keep stuff for years thinking that I or somebody else might need some day ... and then when I finally decide to throw away some of my old treasure thinking that nobody will ever need any of it, I find that somebody could use what I just threw away. I could see in my mind's eye exactly where the part was, but when I went to check if it somehow didn't get tossed, there was only a blank spot.
You can turn a snug fitting disk out of wood with a ¼" hole in the center. Install a carriage bolt through the hole in the float housing so that the head is on the inside and put a nut on the outside to secure it in place. Then with the filter in place install the disc so that the carriage bolt go through the hole. Secure with a rubber washer, a fender washer, and a wing nut or a fancy plastic knob with a threaded brass insert.
I did some searching and it looks like the actual Fein parts may not be available. Once upon a time, Fein claimed that they would support their products forever. I guess that we now know how long forever is.
If you know someone that has a lathe they can make the part that holds the filter. :)
Thanks to your pictures, I will be making the piece, as soon as I can, lol. I might carve the other one, the lock one, out of boxwood... Stay tuned for some Argie ingenuity! LOl. I could not be doing it without your help. Thank you.
@Emiliano Achaval
Great news! I knew that I had an extra that was part of a package deal of filters, brushes, and hose. As I was dozing off last night, it suddenly popped into my head where it was stored. I will put it in a small flat rate box early next week.
WOW!!! You made my night!! Bill I will send you a message with my address!! I will be cutting some blanks next week, I will send you something!! Thank you very much!!! Aloha
I want to give you guys an update. I purchased a filter and bags for my Fein vacuum. I had somehow after almost 20 years, misplaced the plastic lock for the filter. @Bill Boehme somehow had a spare in his shop!! He graciously sent it to me. I got my vacuum going now.... Thanks for all the help. Aloha
